Toymods » Tech & Conversions » Piston strength - I run an SC14 at 18psi on 4AGZE pistons
nick.parker
January 2005
Piston strength - I run an SC14 at 18psi on 4AGZE pistons Sun, 24 July 2005 12:14 Go to next message
I finally got my AW11-GZE up and running with an SC14. It is running custom engine management and 18psi of boost (yes I know that sounds very high Wink ).
I am slightly concerned about the reliability of the pistons.
I will probably get some forged pistons in the next couple of weeks anyway, but can somebody comment on using the 8.0:1 ZE pistons at this level of boost. As far as I am aware, I don't know ANYBODY who has run this much boost with an SC14, which is actually not spinning the SC any faster than a 168mm/120mm pulley combo with the SC12......And if it seems to good to be true (acceleration is so good) then this has surely got to end in tears!
Cheers, Nick
car details and moderate boost tuning run video here: -
http://www.e-wire.net.au/~nrparker/MR2/NewEngine/n ew_engine.htm
feral4mr2
Bundaberg, Qld.
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Sun, 24 July 2005 12:22 Go to previous messageGo to next message
the aw11 gze pistons are forged and will handle that amount of boost with out any dramas.
its more in the tuning that you should be worried about. Smile
nick.parker
January 2005
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Sun, 24 July 2005 12:34 Go to previous messageGo to next message
Hi Feral,
I agree tuning is ABSOLUTELY critical! I have tuned the car with a wideband O2 (damn handy) and basically run 0.85 lambda everywhere above atmospheric pressure, and spark advance is down to 20 degrees at 18psi. And this surprisingly works on 95 octane. Though I'll be using 98 for safety. Its not quite optimal for power, but I'm just playing it safe for now.
I think I can keep it from detonating BUT its the mechanical strength of the pistons that I'm worried about.
Regards, Nick
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Sun, 24 July 2005 13:20 Go to previous messageGo to next message
What's it putting out? Or haven't you dyno'd it yet?
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Sun, 24 July 2005 20:29 Go to previous messageGo to next message
Heya Nick,
i think the mechanical strenth of most pistons is fine... it's detonation that is the death of them... even cast pistons are often fine, but the difference is that the forged tc ones are tougher and resists damage from detonation better than cast...
and it is mainly the ring lands that will fail before anything else (or rings), as the crown of the pistons is quite solid... the GZE pistons look like a nice design...
start very safe on timing, get the AFR's correct (.85 sound squite rich enough to start), then feed in a little more timing... there is definitely heaps to be gained from more timing, but there is the dange of blowing things apart with too much.... more power.... or safer pistons Wink
have fun n good luck!!
nick.parker
January 2005
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Mon, 25 July 2005 02:13 Go to previous messageGo to next message
I haven't dynoed it yet mrshin, but its pulls lots harder than my
old AW11 with 11.5psi, no cat and HKS pod filter which I estimate was atleast around 170hp crank.
I'm running 18psi with the original cat and exhaust which I'm sure is crippling it a bit the moment. Also, I still need more fuelling before I can start pushing it. The 365cc's would be bang on 90% duty at 6000rpm (I've only revved to 5500rpm because of this), even 440cc's would be at 93% duty at 7500rpm, 0.85 lambda which is barely ok. Maybe I should start looking at some 550s......
Cheers, Nick
Irish
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Wed, 27 July 2005 23:09 Go to previous messageGo to next message
Hey Nick. I had a piston/ring failure on a 4agze SC14 2 weeks ago and I was only running around 14psi. I guess there is an ecception to every rule. Mind you, I was towing a 500kg trailer and overtaking a 50m road train at the time.
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Wed, 27 July 2005 23:13 Go to previous messageGo to next message
Irish, did you hear any abnormal noises.. like pinging/tinkling in the leadup? or it was never detected?
Irish
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Thu, 28 July 2005 00:19 Go to previous messageGo to next message
Nah, no det. I presume that it was just too much boost. I had confirmed that I had the fuel for the boost. It was a warm day and I had been on boost for 1000km continuously (no bypass valve). I was not looking at the time but my estimated speed was 160-180kmph. I guess I had a little too much faith in toyota over-engineering. Anyway, it gives me an excuse to build a good engine.
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Thu, 28 July 2005 05:55 Go to previous messageGo to next message
can you cnfirm if it was the piston ring lands or the actual rings that let go first?
Irish
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Tue, 02 August 2005 08:59 Go to previous messageGo to next message
I won't be able to confirm what broke till I tear down the motor.
fatmr2
Re: Piston strength - I run an SC14 at 18psi on 4AGZE pistons Tue, 02 August 2005 09:18 Go to previous message
nick.parker wrote on Sun, 24 July 2005 22:14
Well, mine ran 22.5psi with gze pistons and it didnt miss a beat
It has nothing to do with boost but with the tuning as has already been said.
My brothers car ran 30 psi on just forged pistons and held together without any problems.
A good computer and tune will be your best friend Smile
Previous Topic:Turboing NA 2JZ
Next Topic:TA22 - Need help from someone with an auto
Current Time: Sat Oct 17 18:43:37 UTC 2026
Total time taken to generate the page: 0.011888027191162 seconds
