Toymods » Tech & Conversions » 1jzgte and 2jzge, Q's
Loosecannon
icon10.gif   1jzgte and 2jzge, Q's Fri, 13 December 2002 12:08 Go to next message
Can someone tell me if the bolt pattern on a 1j flywheel is the same on a 2jzge??, I have a 1j in my boat and I'm thinking about puttin a 2jzge in my other boat
Also what info is available for the 2j?, like wiring info, mod's etc, etc, what about putting a 1ggze supercharger on it to up the perfomance a little!... has anyone done this??( they put them on Holden V6's to get a mild increase), just wanta try something else!
Thanks in advance
Dave
humble
Brisbane, QLD
Re: 1jzgte and 2jzge, Q's Fri, 13 December 2002 12:32 Go to previous messageGo to next message
Talk to gianttomato on the forums Smile He's got one radical NA 2JZ. If you want, I think I could possibly help you with the wiring, depending on which car the motor came out of.
Re: 1jzgte and 2jzge, Q's Fri, 13 December 2002 13:00 Go to previous messageGo to next message
The bolt pattern is the same, but the flywheels will be different. The 1JZGTE runs a R154, whilst the 2JZGE runs a W58.
Putting a 1GGZE blower is certainly doable, but the std CR is 10:1, so you would most likely have to fit a decompression plate. The 1GGZE blower would probably also be a little too small for the job. I believe Swift Racing do a blower kit for them at great expense. In the US, most guys are turbocharging them, with great results. There otherwise is relatively little out there.
I have pinouts for the std Supra 2JZGE ECU, so whenever you want them PM me.
Cheers Dave
Loosecannon
icon14.gif  Re: 1jzgte and 2jzge, Q's Fri, 13 December 2002 13:08 Go to previous messageGo to next message
Thank's for your reply's guy's!!!!, Dave I've sent you an email
Regards
Dave
Re: 1jzgte and 2jzge, Q's Sat, 14 December 2002 07:44 Go to previous messageGo to next message
Properly tuned and intercooled there isn't a reason you couldn't run a S/C with the 10:1 compression. There is a turbocharged S2000 in Perth using standard compression and those things have like 11.5:1 compression!
humble
Brisbane, QLD
Re: 1jzgte and 2jzge, Q's Sat, 14 December 2002 09:24 Go to previous messageGo to next message
Not to mention water injection Smile
hydro
Re: 1jzgte and 2jzge, Q's Fri, 27 December 2002 09:02 Go to previous message
Mr Cannon, are you going to Dargle? After all, us Toyota's have gotta gang up on that Wasp RB30 thing.
Previous Topic:Diff Seal leaking.
Next Topic:AE86 diff control arms
Current Time: Thu Oct 22 06:53:50 UTC 2026
Total time taken to generate the page: 0.0056419372558594 seconds
