Toymods » Tech & Conversions » Recommened ST205 Gearbox Oil, other shift problems?
zasa
Recommened ST205 Gearbox Oil, other shift problems? Mon, 25 July 2005 06:22 Go to next message
What is a suitable oil I can use for the above? Gears a little stiff, so I think changing the oil is a good place to start for now.
Thanks.
[Updated on: Mon, 01 August 2005 03:35]
berad
Re: Recommened ST205 Gearbox Oil? Mon, 25 July 2005 06:59 Go to previous messageGo to next message
not sure about the 205 but the 16* and 18* the manual recomends castrol auto transmission fluid
Toobs
Re: Recommened ST205 Gearbox Oil? Mon, 25 July 2005 07:04 Go to previous messageGo to next message
ST205 gearbox and all 3 differentials take API GL5 75W/90 "Manual" gear oil.
The same as the ST185 and I would also assume the ST165.
berad
icon13.gif  Re: Recommened ST205 Gearbox Oil? Mon, 25 July 2005 07:38 Go to previous messageGo to next message
lol my book is accurate as i see lol
Toobs
Re: Recommened ST205 Gearbox Oil? Mon, 25 July 2005 09:28 Go to previous messageGo to next message
Haha its probably accurate for the Auto gearbox... just not the manual.
zasa
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 03:15 Go to previous messageGo to next message
I tried a couple of things over the weekend:
1. As advised by Justen, I dropped the existing fluid (Penrite 75/90 full synthetic) and replaced it with Dexron III. However, this made the shifting even harder when cold, and was not much better when warm. So I'll be dropping this stuff and going back to full synth, perhaps another brand?
2. The problem is that it's very difficult to shift into 3rd and 5th gears, and down into 2nd. Attempting to shift without double clutching is almost impossible. I find that reving it in neutral when shifting up can sometimes be the only way to get into 5th and 3rd gears. Forcing it really feels like I'm going to break something.
I'll be checking the shifter cables for kinks this weekend.
Here are some thoughts:
- Syncro problem? However the shifting sometimes works perfect when shifting into and down. It almost feels like the gears are not linked properly and just jams the shift. Wouldn't syncro wear present itself all the time? (like it did in my old 185)
I've yet to come accross a broken ST205 box. I don't believe this one is anywhere near 100k.
The clutch is a twin plate, with low K's, and takes a bit of leg muscle to engage.
Ideas anyone?
zasa
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 04:51 Go to previous messageGo to next message
How difficult is it to adjust the clutch in a GT4?
Classique71
Colac, Victoria
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 08:55 Go to previous messageGo to next message
sounds like syncros to me - youll be hard pressed killing the gearing in those things - not even with the power the white ones capable of.
I had similar feel issues with my old st185 box - though it was a bit easier when things warmed up
ST205 box i dont have any issues with so far
zasa
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 09:02 Go to previous messageGo to next message
OK.
I just find it hard to believe that the syncros on 205 box would last far less than a 185 box.
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 09:10 Go to previous messageGo to next message
Any one tried Redline?
Works wonders in RWD boxes.
Classique71
Colac, Victoria
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 09:34 Go to previous messageGo to next message
Depends on the usage quite a bit too Zasa ..
Was the white ones box a second hand or new one ? I know my box has at least 75 thousand KM on it.
heard about that redline stuff too as mentioned - may be an otopin to look at
zasa
Re: Recommened ST205 Gearbox Oil, other shift problems? Mon, 01 August 2005 11:22 Go to previous messageGo to next message
I'll have a look for the redline stuff.
The box was second hand.
Justen reckons it was fine until he got the clutch put in. After that, things started to get a little stiff, and it's gradually worsened.
Johnny
Sydney, OZ
Re: Recommened ST205 Gearbox Oil, other shift problems? Tue, 02 August 2005 05:58 Go to previous messageGo to next message
Try Castrol Transmax Z, full synthetic which is must better than Dexron III. We were having the same problem with a LSD GZE box which are very similar and this was the fix. With the penrite, it also kept blowing the seals due to the upgraded oil pump.
zasa
Re: Recommened ST205 Gearbox Oil, other shift problems? Tue, 02 August 2005 11:22 Go to previous messageGo to next message
cheers Johnny, i'll have a look for that tommorrow
Johnny
Sydney, OZ
Re: Recommened ST205 Gearbox Oil, other shift problems? Wed, 03 August 2005 01:32 Go to previous message
Ring the Green Goanna ph (02)98977551 (specalist oil distributer) and ask for Angelo, supplies alot of hard to get oils that we use at work and supplies/advises many the front running IP cars, Ralliart etc on what to use.... Pity he drives a Girly a Ex-Mirage Cup car!
Previous Topic:funni/wired temp gauge
Next Topic:Removing Rear Bumper from AE86
Current Time: Sun Oct 18 22:59:35 UTC 2026
Total time taken to generate the page: 0.0059139728546143 seconds
