Toymods » Tech & Conversions » 3sgte Coolant temps..?
EVL-184
June 2005
3sgte Coolant temps..? Mon, 25 July 2005 09:38 Go to next message
hey all, for a while (well since my engine swap 3sgte into ST184)
i think its running too cold..
accourding to my autometer gauge (which has sensor in top hose) its only running at 125 fahrenheit, which is about 51 celsius..
and that even in the summer, the other day (sunday ) it got to about 150 fahrenheit,or 65 celsius..? and on both accounts the factory gauge dont move..!!! it just stay in the middle of the table..
Whats is it meant to run at .?
should i change the thermostat..?
spectral
Re: 3sgte Coolant temps..? Mon, 25 July 2005 09:52 Go to previous messageGo to next message
yep change your thermostat.. its stuck open.
It should open at 82degrees, so your engine temp (once warm) shouldn't vary too far from there.
Aust162
Melb, Victoria
Re: 3sgte Coolant temps..? Mon, 25 July 2005 09:58 Go to previous messageGo to next message
Yep, it should be running warmer than that.But If your factory guage is reading half way and you autometer is only reading about 50-60degrees than one of them is wrong..
Do your thermo fans turn on?
EVL-184
June 2005
Also would it be worht spending a shit load and getting a TRD one or just the stock one from toyota..?
EVL-184
June 2005
Re: 3sgte Coolant temps..? Mon, 25 July 2005 10:04 Go to previous messageGo to next message
yeah i was just going to add that ,m the thermos turn on, so i think maybe the sensor in the top hose is fcuked..? but it was all brand new..!?
that what i dont understand...?
EVL-184
June 2005
Re: 3sgte Coolant temps..? Tue, 26 July 2005 09:05 Go to previous messageGo to next message
any one else... got input..?
V8_MA61
Re: 3sgte Coolant temps..? Tue, 26 July 2005 11:53 Go to previous messageGo to next message
Are your thermos working properly? Did you use the 3sgte sensor that was in the bottom of the rad?
EVL-184
June 2005
Re: 3sgte Coolant temps..? Tue, 26 July 2005 13:11 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 26 July 2005 21:53
Yep, i was actually running the GT4 rad and sensor with my stock 5s engine, and then fitted the 3SGTE...
would it depend on the location of the sensor, i was thinking of putting in the actual housing at rear of head..?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: 3sgte Coolant temps..? Tue, 26 July 2005 13:22 Go to previous message
I have my 3S-GTE running at similar temps. I have the 71°C TRD thermostat in mine, and last I checked it was functioning correctly. My thermo-fans run fulltime from ignition to shut-off. I also need to replace my thermo switch because I don't have one currently. Confused
Previous Topic:2t-g cam timing marks
Next Topic:3UZ-FE into Toyota Harrier/Lexus RX
Current Time: Wed Nov 25 06:53:53 UTC 2026
Total time taken to generate the page: 0.0060069561004639 seconds
