Toymods » Tech & Conversions » 3sge dyno results?
chitown383
3sge dyno results? Mon, 25 July 2005 13:26 Go to next message
http://photos.friendster.com/photos/22/04/7524022/1442174715419l.jpg
following the dyno day at jaustech recently, my st184 with 3sge gen 3 conversion put out 112.4kw at the wheels and 167.1Nm of torque.
So far powerwise, all thats been changed are the headers and piggyback ecu.
Was wondering if anyone can help out in comparing these figures say to other N/A cars (i.e dyno specs of say the integra type r or other similar cars) as i am not too sure if this is a good figure.
Cheers.
[Updated on: Tue, 02 August 2005 12:04]
ST162GT-R
QLD, Gold Coast
Re: 3sge dyno results? Mon, 25 July 2005 22:27 Go to previous messageGo to next message
i would say yes thats a good figure, as standard type r's DC2s put out about 95-105kw at the wheels, but i would say the torque is rather little, are you sure its 112kw at the wheels and not at the engine?
verbatim210
Victoria, Melbourne
April 2005
Re: 3sge dyno results? Mon, 25 July 2005 23:41 Go to previous messageGo to next message
is a 184 suppose to be a 185? dumb question but wot is a 184 really?
i thought it was just 182 standard and 185 gt4
Kingswood
Hobart, tassie
Re: 3sge dyno results? Tue, 26 July 2005 00:21 Go to previous messageGo to next message
well I had a dead stock sr20 de with a pod filter in me old Ae71 and that made 80rwkw's was very dissapointed. Specially after just coming from a 164rwkw holden v8 and 148rwkw rb20det.
Hunty
Re: 3sge dyno results? Tue, 26 July 2005 00:56 Go to previous messageGo to next message
dude i was at that dyno day my mr2 turbo pulled 134kw so your doin pretty well!!
matt86sx
Gold Coast, QLD
Re: 3sge dyno results? Tue, 26 July 2005 01:07 Go to previous messageGo to next message
verbatim210 wrote on Tue, 26 July 2005 09:41
ST184 was the Australian delivered 5th gen FWD Celica. The JDM one was the ST182. The reason for the difference is that the Aus version came with the 5SFE engine, while the JDM version had the 3SGE, hence the different codes.
Those ending in "2" are fitted with 3S series engines, hence the 4th gen ST162, 5th gen ST182 and 6th gen ST202. Those ending in "4" have 5S series engines. The 5th and 6th gen Celicas came to Australia with 5SFE engines, hence ST184 and ST204 instead. Both engines have pretty much the same block (S-series), but different capacities: 3S = 2.0L, 5S = 2.2L.
Of course, those ending in "5" are the GT-Fours, with 3S-GTE motors as you have already identified.
-Matt
RWDboy
Re: 3sge dyno results? Tue, 26 July 2005 02:34 Go to previous messageGo to next message
chitown383 -> That dyno result is pretty fair.
Comparing dyno figures is a bit tricky, because *every* (and i mean every) dyno will read differently, they will be calibrated differently, and every dyno runs a 'fudge' factor. We ran an S12 on the dyno later in the day that made 67kw - then we just changed the fudge factor and the dyno magically came up with 80kw Wink
And the 'torque' figure is subject to gearing - most runs were done in 5th gear I think, in which case you need to correct for that.
jonchai
Adelaide - Race Central
Re: 3sge dyno results? Tue, 26 July 2005 03:08 Go to previous messageGo to next message
yep......absolutely right!! to get a true figure, you need to get a car that has been on the same dyno, preferably with same tuner!! A midly modified MR2 with a 3sge put out 100rwkw on the dyno where mine did 97rwkw. comparing that mine is some 10years earlier than the MR2, i'd say mine is good!
again..to get a fair figure....you'd need to be on the same dyno!
chitown383
Re: 3sge dyno results? Tue, 26 July 2005 03:10 Go to previous messageGo to next message
cheers guys,
i been reading around and average loss from flywheel to wheels is 15-18% (????????) so if that were the case i would be gettin roughly 132kw at the fly. But how come stock cars such as the dc2r, prelude vtir and corolla sportivos which are rated at 140+kw at the fly are getting dyno results between 100 and 110kw at the wheels, this is almost more than 25% loss???
ST162GT-R
QLD, Gold Coast
Re: 3sge dyno results? Tue, 26 July 2005 03:12 Go to previous messageGo to next message
I agree with that jonchai, better to stick with the same tuner and dyno, unless you got a 3sfe stock putting 200kw at the wheels then its safe to say its a bogus dyno machine.
ST162GT-R
QLD, Gold Coast
Re: 3sge dyno results? Tue, 26 July 2005 03:15 Go to previous messageGo to next message
chitown383 wrote on Tue, 26 July 2005 13:10
cheers guys,
i believe the drive train loss is more then 15-18%, more in the regions of 25-30%, but the cars mentioned above have variable valve and ignition timing as well as high compressions 11:1 i believe, better tech as well.
jonchai
Re: 3sge dyno results? Tue, 26 July 2005 03:20 Go to previous messageGo to next message
think of it this way!!!!
If all that mattered was numbers, dyno comp. entrants in Autosalon's would only need to show-up with a dyno graph! there is a reason why they do dyno runs on the same dyno, with same tuner, in a relatively short space of time. all this is because ambient temperature affect performance as does bogus offsets!
If you really want numbers...go to Morpowa. their readings are BRILLIANT... Wink if you know what i mean.
buck naked
Re: 3sge dyno results? Tue, 26 July 2005 08:24 Go to previous messageGo to next message
Most MR2's with 2nd gen 3SGE's (often with simple mods) get 95-100kw at the wheels, so 112.4 is well above average. What was the 3SGE out of? Know much about what was done with the piggyback ECU?
chitown383
Re: 3sge dyno results? Tue, 26 July 2005 09:07 Go to previous messageGo to next message
the 3sge came out of a 95 st202 celica, as for the piggyback ecu i have no idea how its been tuned as it came from an imported st202 ss-3 half cut. on the ecu box itslef there is an advance sticker of some sort but thats about it. anyway of findin out more about it??
CelicaRA45
nth ringwood, Victoria
Re: 3sge dyno results? Tue, 26 July 2005 09:59 Go to previous messageGo to next message
so you have a gen 3 3sge or mr2 bathurst same motor as they changed from 12month 93 from gen 2 to your gen 3
3sfe
Re: 3sge dyno results? Tue, 26 July 2005 11:29 Go to previous messageGo to next message
Doesn't the st202 ss-II have a beams motor(200hp)?
Alchemist
Re: 3sge dyno results? Tue, 26 July 2005 12:23 Go to previous messageGo to next message
I got 94.1RWKW out of a mildly modded(extractors, HKS intake, exhaust) Gen 2 3S-GE, but I think you'll find you have a Gen 3, not a Gen 2. The stock Gen 3 3S-GE's I've seen tend to put out 105RWKW or so.
112 RWKW is a mighty fine effort out of a N/A 2.0L, I mean my 2JZ-GE only puts out 124RWKW. Although I've got HKS Intake, HKS extractors and a cat back exhaust now so I'll be expecting quite a lot more next dyno day.
*edit* here's my graph just for comparison.
http://members.iinet.net.au/~warrenh/MR2/dyno_chart_web.jpg
[Updated on: Tue, 26 July 2005 12:25]
LiL_MiC
Melb
Re: 3sge dyno results? Tue, 26 July 2005 12:47 Go to previous messageGo to next message
dont you mean fwkw?
Alchemist
Re: 3sge dyno results? Tue, 26 July 2005 13:55 Go to previous messageGo to next message
Sorry, a little confused Smile My MR2 was RWD, so RWKW, his Celica is FWD so I should said FWKW. My bad.
chitown383
Re: 3sge dyno results? Tue, 26 July 2005 14:12 Go to previous messageGo to next message
ok im confused also. i always thought that the gen 1: 3sge was 165 ps (121.36 kw) / 6800 rpm, gen 2: 180 ps (132.39 kw) / 7000 rpm, and gen 3: 200 ps (147.10 kw) / 7000 rpm. these are flywheel results of the st202.
figures obtained from:
http://www.auto.vl.ru/catalog_eng/toyota/celica/19 95_8/
apparently both gen 2 & gen 3 engines look exactly the same according to some guy who did a gen 3 conversion on the oz celica forum???
RWDboy
Re: 3sge dyno results? Tue, 26 July 2005 14:41 Go to previous messageGo to next message
Dude you are sweating way too much over the dyno result Razz
An ST202 has the Gen 3 3S-GE, not the Gen 2. Also - don't even bother trying to approximate your flywheel kw, it's not possible with a dyno to do so.
Also, Gen 3 and Gen 2 and Gen 1 3S-GE's came out in many different flavours and tunes in different countries/regions due to emissions regulations etc.
buck naked
Re: 3sge dyno results? Wed, 27 July 2005 01:09 Go to previous messageGo to next message
chitown383 wrote on Tue, 26 July 2005 22:12
You're skipping a generation.
The gen 2 from the ST182 and earlier SW20's is about 117kw. The ST202 had both the gen 3 132kw and the gen 4 BEAMS 147kw motors.
CelicaRA45
Re: 3sge dyno results? Wed, 27 July 2005 06:37 Go to previous messageGo to next message
the gen 4 beams came out the last 6months in the st202 ss3 version
verbatim210
Victoria, Melbourne
April 2005
Re: 3sge dyno results? Thu, 28 July 2005 03:35 Go to previous messageGo to next message
hey matt thx for the reply
curious to know would the
2.2-fe own the
2.0-ge ?
coz i hear the ge head is more
performance oriented
verbatim210
Victoria, Melbourne
April 2005
Re: 3sge dyno results? Thu, 28 July 2005 03:36 Go to previous messageGo to next message
(crap i clicked reply instead of pm)
how embarassing
terra
July 2005
Re: 3sge dyno results? Sun, 31 July 2005 13:21 Go to previous messageGo to next message
3sge is faster then a 5sfe, even with the 200cc deficit. it revs higher, and is engineered better (well, its performance orientated).
ge runs proper cam/gears whereas the fe cams are gear linked internally so adjusting them is a bitch. ge heads are also more oval to make better power. other things such as valve angles etc are also different.
a 260hp+ 3sge is a drop off at tuner and pick up later affair, whereas getting someone to pull similar results from a 5sfe is going to be a bigger headache.
verbatim210
Victoria, Melbourne
April 2005
Re: 3sge dyno results? Sun, 31 July 2005 14:19 Go to previous messageGo to next message
thanks terra, very helpful information indeed
kingmick
Banned by his request
moved to tamworth
Re: 3sge dyno results? Mon, 01 August 2005 09:39 Go to previous messageGo to next message
talk to jonchai he has spent $15k on his motor alone so he should be up there with the best of the 3sge's.
chitown383
there is nothing wrong with a pretty stock 3sge making making 150hp at the wheels. but id take it with a grain of salt. a full race version of a 7age does around the 200-220hp at the wheels depending on the chassis dyno. power figures still make me laugh, a $120k super tourer motor makes around the 300hp mark so,what can i say.
mick
terra
July 2005
Re: 3sge dyno results? Mon, 01 August 2005 09:54 Go to previous messageGo to next message
TRD Japan have all the parts you need if you want to make monster na 3sge's ... now the hard bit is getting the money for it all Smile
remember the old super tourers had A LOT of restirctions on them too, kinda like how WRC cars are restricted Smile
kingmick
moved to tamworth
Re: 3sge dyno results? Mon, 01 August 2005 10:44 Go to previous messageGo to next message
yes they did have a lot of restrictions, they could only turn the head the other way round,build them light{titanium vales at $300 each} and revvy{but only last 1000km},spend 100k's + on flowing heads,dry sumped,have mega dollars spent on tuning,have minimum power lose from auxiliaries,have very good intake system,optimum injector placement,etc etc.
mick
RWDboy
Re: 3sge dyno results? Mon, 01 August 2005 12:19 Go to previous messageGo to next message
terra wrote on Sun, 31 July 2005 22:51
That is ridiculous...to make 260hp from a 3S-GE takes a *lot* of work.
charliechalk
Re: 3sge dyno results? Mon, 01 August 2005 12:58 Go to previous messageGo to next message
Nar, buy a beams and you're almost there haha Wink . I'ld say 260 would be a lot of work, from the first gen that would be doubling output even gaining 60bhp from the 4th gen beams would be expensive to say the least.
As far as drivetrain loss is concerned it varies from car to car, for instance there was a dyno result of a sportivo corolla putting out i think it was around 120kw at the wheels, now if the dyno result is correct that's only 15% drivetrain loss. Also typically FWD's have less drivetrain loss then RWD's
That's a very interesting torque curve though, anyone know why there's a servere drop after about 4500?
RWDboy
Re: 3sge dyno results? Mon, 01 August 2005 13:40 Go to previous messageGo to next message
Possibly the hub dyno Smile We were getting kinda kinky torque curves on the 2WD cars, probably related to open-diffness. The AWD cars did much better (as they generally have LSDs, viscous couplings in the centre, and of course, more wheels to collect torque curve data from etc)
Hunty
Re: 3sge dyno results? Tue, 02 August 2005 04:01 Go to previous message
nah thats the vtec kicking in bro!!
Previous Topic:KE10 - KP61 front end conversion
Next Topic:Gearbox to fit in 4ag3silver ae86?
Current Time: Thu Oct 22 06:55:31 UTC 2026
Total time taken to generate the page: 0.0104079246521 seconds
