Toymods » General Car Talk » norgen valve, wastegate controller
..J..
opening a can of whoop ass
norgen valve, wastegate controller Tue, 26 July 2005 00:43 Go to next message
was surfing the net today, found a norgen valve / wastegate creep controller for a mere $90 as apposed too $190.
might be worth a look for those after one trying to save some money.
http://autospeed.drive.com.au/cms/A_0670/article.h tml?popularArticle
Hodgo
Re: norgen valve, wastegate controller Tue, 26 July 2005 00:47 Go to previous messageGo to next message
Anyone got a login they want to share?
Ribfeast
Newcastle, Australia
March 2005
Re: norgen valve, wastegate controller Tue, 26 July 2005 04:30 Go to previous messageGo to next message
Apparently plumbers carry these, anyone know any that definitely have them? I need one Smile
stradlater
Arthurs Creek, Victoria
Re: norgen valve, wastegate controller Tue, 26 July 2005 04:47 Go to previous messageGo to next message
AHAHAHAhheheheheheheh...
$190?? BAh..
$90? Shesh..
I paid $40 for mine including all the fittings.....
Ribfeast
March 2005
Re: norgen valve, wastegate controller Tue, 26 July 2005 05:36 Go to previous messageGo to next message
Don't care unless you share as to where Wink
stradlater
Re: norgen valve, wastegate controller Tue, 26 July 2005 05:57 Go to previous messageGo to next message
http://www.hishose.com.au/
I bought it from the shop in person, I'm not sure that they do over the internet sales.
Ribfeast
March 2005
Re: norgen valve, wastegate controller Tue, 26 July 2005 06:51 Go to previous messageGo to next message
Fantastic, thanks mate Very Happy
1JZ.747
Osama's hideout
Re: norgen valve, wastegate controller Tue, 26 July 2005 23:33 Go to previous messageGo to next message
yep, i paid about $50 for mine back in the twin turbo days, it was perfect. brought boost on fast and it never spiked. and i only used that valve nothing else with it.
Merudo
Central Coast, NSW
February 2005
Re: norgen valve, wastegate controller Tue, 26 July 2005 23:41 Go to previous messageGo to next message
1JZ.747 wrote on Wed, 27 July 2005 09:33
Just had a read through what I could on that article... by the sounds of this device, it certainly would help with the 1G Laughing
[Updated on: Tue, 26 July 2005 23:45]
Ribfeast
March 2005
Re: norgen valve, wastegate controller Wed, 27 July 2005 00:31 Go to previous messageGo to next message
Anyone able to post the article up? Is there a specific type of norgren valve that I would need to buy?
Merudo
Central Coast, NSW
February 2005
Re: norgen valve, wastegate controller Sat, 30 July 2005 01:34 Go to previous messageGo to next message
ribfeast, did you end up getting this?
Ribfeast
March 2005
Re: norgen valve, wastegate controller Sat, 30 July 2005 10:25 Go to previous messageGo to next message
I will as soon as someone tells me which one to buy (preferaly a model/part#). I'm hangin out like a crab's eye for one!
Ribfeast
March 2005
Re: norgen valve, wastegate controller Sun, 31 July 2005 00:38 Go to previous messageGo to next message
Is this the one to get?
http://www.wak-tt.com/mods/boostmachine/DSCN7373.JPG
http://www.wak-tt.com/mods/boostmachine/boostmachi ne.htm
[Updated on: Sun, 31 July 2005 00:42]
1JZ.747
Osama's hideout
Re: norgen valve, wastegate controller Mon, 01 August 2005 23:52 Go to previous messageGo to next message
see the one on the left,
black body with grey top,
thats the one i was talking to you about.
ring me if you want im free today.
1200det
Re: norgen valve, wastegate controller Tue, 02 August 2005 00:06 Go to previous messageGo to next message
I would be interested to know how to set these up Rolling Eyes
Ribfeast
March 2005
Re: norgen valve, wastegate controller Tue, 02 August 2005 01:06 Go to previous messageGo to next message
Sweet, if you know more details as to what model # it is etc then I'll order one from hishose.com.au. Smile
Johnny
Sydney, OZ
Re: norgen valve, wastegate controller Thu, 04 August 2005 02:36 Go to previous messageGo to next message
Hmm... We use these on our plant and from memory they are more like $60, but that's direct from Norgen, if you guys get confirmed numbers I'm willing to ring the rep to find out the real cost.
Ribfeast
March 2005
Re: norgen valve, wastegate controller Fri, 05 August 2005 05:44 Go to previous message
OK I took one for the team and plonked down the cash for the article, here is the bits we need, any pricing you can get me would be appreciated Smile
The Parts
The parts were sourced from the German company IMI Norgren Pty Ltd - branches in most states and countries. The parts that were used were:
* 1 x R07-200-RNKG Inline 07 1?4 Regulator Relieving 7Bar;
* 1 x V07-200-NNKG Inline 07 1?4 Relief Valve 7 Bar;
* 2 x 2069-02 07 Spring 0.7 Bar (brown);
plus mounting brackets and four 1?4-inch barbed hose fittings to suit the regulator and relief valve. The total cost was A$83 (including GST).
Note that the pressure reg and relief valve are nominally 7 Bar (ie are designed to set pressures up to ~100 psi), and so you need to buy the softer springs (rated at 0.7 Bar - 10 psi) to go inside each of them. The bodies easily unscrew and spring replacement takes only a few moments. If you are going to be running very high boost, retain the higher rated springs as well - for 1 Bar (14.5 psi) boost, the softer springs worked fine, despite their nominal 10 psi setting. In addition, you will need a metre or so of 1?4 -inch fuel hose (or similar high temp hose) and 6 hose clamps. In fact I used 5/16th ID hose - the 1?4 inch fittings seemed a little large for 1?4 inch hose.
Previous Topic:Inspiration for all ae86 owners.. :D
Next Topic:Minispool for G series...where?????
Current Time: Sat Oct 24 09:51:41 UTC 2026
Total time taken to generate the page: 0.0060050487518311 seconds
