Toymods » General Car Talk » MA61 Diff Question
TRD_Supra
On Probation
Hobart
MA61 Diff Question Tue, 26 July 2005 01:52 Go to next message
G'day guys
i have recently stuffed the gears in my MA61 LSD diff, and obviously need a new one!!! but cause MA61 parts are almost impossible to find, i was wondering if its possible that an MX73 Cressida LSD be fitted...Has anyone done this before ? wat are some of the other options... the reason y i mention MX73 is due to its ratios and IRS... how would an SA63 or MA70 LSD go ?
Cheers Nick
Re: MA61 Diff Question Tue, 26 July 2005 02:00 Go to previous messageGo to next message
You can use parts from any F series diff. SA63 = T series, MA70 = G series, so no they won't fit. MX73 = F series so that's fine, but it won't have an LSD centre.
If you want an LSD your only realistic options are to buy another MA61 diff or buy an aftermarket LSD centre (eg TrueTrac).
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:02 Go to previous messageGo to next message
hmm ok... so u r saying that if i bought an MX73 diff that it shoiuld be fine to go in ? just won't be LSD ? cause this bloke at BIP reckons that MX73 diffs are LSD ?
Henn
Rosanna, Melb
Re: MA61 Diff Question Tue, 26 July 2005 02:06 Go to previous messageGo to next message
MX73 = Open.
If it's just your gears which are stuffed, get the crown and pinion from an MX73 (or any other F-series diff, IRS or not) and transfer them over to your LSD centre. The crown and pinion should always be used as a pair though, don't mix and match.
Hen
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:07 Go to previous messageGo to next message
so u reckon if i just bought the MX73 diff, then had the bit swapped she will be all good ? u think that is the best option ?
Re: MA61 Diff Question Tue, 26 July 2005 02:11 Go to previous messageGo to next message
Are you looking for a final solution? or something to get you going again?
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:15 Go to previous messageGo to next message
just something short term... just so i can drive to uni and back.. basically when i did it a loud bang happened and it just went clunk, now when u drive the car (driven once since to test) the car tends to rock aroudn a bit and it make sa loud CLUNK noise in a straight line it will sme times disappear, but going around corners it is very bad and shakes the car and Clunks around... i got a feeling its just the pinion gears but no one sells a gear set just the entire diff, plus its MX73 only.. is the bolt pattern on the MX73 the same as the MA61...
Re: MA61 Diff Question Tue, 26 July 2005 02:19 Go to previous messageGo to next message
Pay $50 for an MX73 diff, and bolt that in.
Don't open it up, just bolt it in.
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:22 Go to previous messageGo to next message
who has an MX73 diff for $50 ?? would it bolt straight up ?
Re: MA61 Diff Question Tue, 26 July 2005 02:23 Go to previous messageGo to next message
Would I tell you to bolt it in if it didn't bolt straight up?
Yian
Lwr Templestowe, Melbourne
Re: MA61 Diff Question Tue, 26 July 2005 02:24 Go to previous messageGo to next message
CrUZsida wrote on Tue, 26 July 2005 12:23
Laughing Laughing
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:25 Go to previous messageGo to next message
.... Confused maybe.... na thats cool thanks for that... everyone i have asked doesn't know if it will bolt in or not.... where would b the best place to ring for a diff.. i have tried Just Toyota, EKW and BIP... BIP wa the chespest for $150
Re: MA61 Diff Question Tue, 26 July 2005 02:29 Go to previous messageGo to next message
It does bolt up. I've done it many times.
Just make sure the top bracket is the same.
Try private wreckers too.
I have no idea whats available in Tas.
Corona RT142
Campbelltown
Re: MA61 Diff Question Tue, 26 July 2005 02:30 Go to previous messageGo to next message
err wrecker, what about a diff out of an RT142 avante with irs they run f-series diffs as well no lsd like the MX73 though.
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:35 Go to previous messageGo to next message
oh ok cool.. thanks for your help guys... when u say make sure the top bracket is the same... i am basically getting them to put hte diff in a crate and send it down... so how do i find out if the bracket is hte same ?? or does the MX73 have the same bracket ? just incase its been removed or modded ?
Re: MA61 Diff Question Tue, 26 July 2005 02:40 Go to previous messageGo to next message
Doesnt matter.
You reuse the MA61 one if its different.
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 02:44 Go to previous messageGo to next message
so i just really need the diff and thats it ?
Re: MA61 Diff Question Tue, 26 July 2005 02:53 Go to previous messageGo to next message
If the diff is the only think broken on your car, then the diff is the only thing you need.
Just like the diff on the right, but you dont need that extra bracket on top.
http://www.conceptual.net.au/~peewee/diff/T_vs_F_1.jpg
Re: MA61 Diff Question Tue, 26 July 2005 03:13 Go to previous messageGo to next message
So will an MX73 diff fit in an MA61?
Re: MA61 Diff Question Tue, 26 July 2005 03:19 Go to previous messageGo to next message
I don't beleive so no.
Yian
Re: MA61 Diff Question Tue, 26 July 2005 03:32 Go to previous messageGo to next message
CrUZsida wrote on Tue, 26 July 2005 12:53
Errmmm.. is it me? Or is your second toe missing the nail? Confused
Corona RT142
Campbelltown
Re: MA61 Diff Question Tue, 26 July 2005 03:34 Go to previous messageGo to next message
no he just has mung toes like me that curl under, hehe my brother says they need to break each of my toes and straighten them out.
Re: MA61 Diff Question Tue, 26 July 2005 03:37 Go to previous messageGo to next message
Ask Frank.
Its his foot.
Re: MA61 Diff Question Tue, 26 July 2005 03:38 Go to previous messageGo to next message
You can see it here
http://www.conceptual.net.au/~peewee/diff/T_vs_F_2.jpg
Re: MA61 Diff Question Tue, 26 July 2005 03:44 Go to previous messageGo to next message
his toes look like mine... unless they suffered the same fate as his fingers Razz
Re: MA61 Diff Question Tue, 26 July 2005 03:47 Go to previous messageGo to next message
On behalf of The Frank
"Second toes are mung and curled over :)"
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 04:55 Go to previous messageGo to next message
well all my shit is sorted.. i jus tbought an F313 !!!
Re: MA61 Diff Question Tue, 26 July 2005 04:58 Go to previous messageGo to next message
From an MA61?
Lets hope the LSD is still tight.
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Tue, 26 July 2005 04:59 Go to previous messageGo to next message
yep from an MA61 i bought it from Melbourne Toyota Wreckers or osmething like that!! they said its in good cond. so i will take there word for it!
Re: MA61 Diff Question Tue, 26 July 2005 05:16 Go to previous messageGo to next message
Yep, wreckers would never lie.
peeack
Re: MA61 Diff Question Tue, 26 July 2005 05:22 Go to previous messageGo to next message
Hahahah.
ZZT231
melbourne.vic.au
Re: MA61 Diff Question Tue, 26 July 2005 09:46 Go to previous messageGo to next message
TRD_Supra wrote on Tue, 26 July 2005 14:59
Who? I have delt with some of them and I'm sure most are dodgy and think of mega bucks when you want MA61 parts...
Cheers.
Mookie
Tassie
Re: MA61 Diff Question Tue, 26 July 2005 09:58 Go to previous messageGo to next message
I think you meant RA65 Not SA63 you pelican rooter !
Think of somebody you know with a SA63 and a weak diff.
Think really hard about it then get back to me !
TRD_Supra
On Probation
Hobart
Re: MA61 Diff Question Thu, 28 July 2005 08:22 Go to previous message
oh well see how i go!
Previous Topic:17's on twinky
Next Topic:KE70 drift
Current Time: Thu Nov 19 16:00:03 UTC 2026
Total time taken to generate the page: 0.012298107147217 seconds
