Toymods » Tech & Conversions » piston compression ratio
akmehd
carlingford
February 2005
piston compression ratio Tue, 26 July 2005 05:42 Go to next message
ok i just got my4agze motor rebuilt using mahl 7:9:1 ratio pistons and also the head was port n polished. im still running the supercharger at 10psi which used 2 make 95fwkw. being that lower comp pistons have been used snt there a great chancce that the motor will make less power due to the lower compression only running mild boost
help appreciated, michael
V8_MA61
Re: piston compression ratio Tue, 26 July 2005 05:59 Go to previous messageGo to next message
you probly wouldnt want to go much higher comp pistons. As this will cause pinging at that sort of boost. Id either get a bigger blower or install a turbo if you arent happy with your current figures.
kingmick
Banned by his request
moved to tamworth
Re: piston compression ratio Tue, 26 July 2005 06:23 Go to previous messageGo to next message
V8_MA61 you lost me?10psi you could go 10-1 comp with good charge cooling.
mick,yes you will have less power with the lower comp but not a huge amount.are you changing to turbo? i ask as you dont need that low a comp with a sc12 as max boost will be 14psi or there abouts from them. on one of my 4agte motors i have the comp at 8-1 so i can run 30psi on the track.
mick
akmehd
carlingford
February 2005
Re: piston compression ratio Tue, 26 July 2005 12:20 Go to previous messageGo to next message
nah mate im not lookin 2 go turbo as off yet, only prob is that iv payed all this money to get a tops motor and im hoping that i wont notice anything worse than wat it was before. How much power relistically do u think itl be loosing, like somethin drastic or nothin that u would really notice
Also only reason theyre lower comp pistons is because toyota couldnt get the 8:9:1 comp pistons in oversized for many weeks from japan so i had to buy expensive mahl pistons as they were the only ones sourced in oversize at the time. Also has anyone had any experience with Mahl pistons?
Thnks again
[Updated on: Tue, 26 July 2005 12:32]
nick.parker
January 2005
Re: piston compression ratio Tue, 26 July 2005 13:44 Go to previous messageGo to next message
Just for the record. I'm running 18psi with an SC14 supercharger into an internally standard 8.0:1 4AGZE. At 18psi I'm running 20 degrees of advance and about 0.75 - 0.8 lambda on 95 Octane fuel.
I'll admit thats it too much boost, and I can't rev it past 6K on the 365cc injectors (I need 440 for redline!) and I don't sustain the high boost for very long - I'm gonna cut it down to 15 psi soon for reliabilitys sake.
The point is you can DEFINITELY run higher boost with that comp if your fuelling and spark are o.k. I'd get a bigger crank pulley for a start -say around 170mm that should give you more like 13-14 psi, should make the car lots more fun.
Check out my acceleration vid on bottom of this web page :
http://www.e-wire.net.au/~nrparker/MR2/NewEngine/n ew_engine.htm
Regards, Nick
kingmick
moved to tamworth
Re: piston compression ratio Tue, 26 July 2005 22:22 Go to previous messageGo to next message
with a charger on it, you wont even notice it.very small change in hp.
mahle pistons are exellect.
have fun with it.
mick
akmehd
carlingford
February 2005
Re: piston compression ratio Tue, 26 July 2005 22:26 Go to previous message
k thnks mate
Previous Topic:Fuel Tank problem
Next Topic:st141 fuel tank
Current Time: Wed Oct 14 10:44:05 UTC 2026
Total time taken to generate the page: 0.087199926376343 seconds
