Toymods » Tech & Conversions » changing studs/ stud extensions
terrykoun
changing studs/ stud extensions Tue, 26 July 2005 05:59 Go to next message
hey who knows how to change wheel studs??
cause i want to change to longer studs at the rear of my ae92 but i cant find any info on how to change them anywhere. Ive found info on where to get them though.
I was going to go to a mechanic shop and get them to do it but i want to know if its easy and i can do it myself to save $$.
so does anyone know exactly how to change them or knows where to find good info about it?
Rears are drum brakes BTW.
[Updated on: Thu, 28 July 2005 06:59]
kingmick
Banned by his request
moved to tamworth
Re: changing studs Tue, 26 July 2005 06:49 Go to previous messageGo to next message
you could use a hammer but you will more than likely make a mess of it as it needs a fair anount of wacking{sorry to get technical}to get them in, one slip and you will say bye bye to threads. best bet to save money is to put the car safely on stands,and take the hubs of yourself{if you know how?)and get a mechanic or engeneering place to press them in.
can be done with hammer and the right size metal tubes.but i speak from experiance.i had to change a couple of broken stud's on a racecar and was away from the workshop at the track.got the old ones out,got four in and was halfway with the 5th and it slipped when i hit it and stuffed all the threads.pain had to do it all over again.
Toobs
Re: changing studs Tue, 26 July 2005 07:03 Go to previous messageGo to next message
Why hammer them back in?
Hammer the buggers out for sure but then just use an appropriately sized wheel nut and spanner to pull them back in.
kingmick
moved to tamworth
Re: changing studs Tue, 26 July 2005 07:11 Go to previous messageGo to next message
takes to long.
mick
p.s be fine on your ae92 as you have the clearence to get them in.but its going to take awhile.
[Updated on: Tue, 26 July 2005 07:16]
Re: changing studs Tue, 26 July 2005 13:17 Go to previous messageGo to next message
I sometimes use a press because I've got one, but otherwise a hammer, used with some CARE, is fine. Usually to pull them in I tap them a little bit from behind, pull in with an old wheelnut (rattlegun means this only takes a second, long as you're careful), then check with socket+breaker bar. Don't just grab a hammer and randomly belt everything in sight though.
terrykoun
Re: changing studs Thu, 28 July 2005 06:58 Go to previous messageGo to next message
yea..... makes sense, cheers.
I was researching the other day and came across these "stud extensions":
http://www.niceproducts.com.au/wheel_stud/wheel_ac c_1.htm
has anyone ever used these before? How do they go on, and are they easier than replacing the whole stud??
kingmick
moved to tamworth
Re: changing studs/ stud extensions Thu, 28 July 2005 07:57 Go to previous messageGo to next message
just get longer studs.standard stud length is fine unless you are doing a bit of track work, or the standard ones are to short for a rim type.
mick
terrykoun
Re: changing studs/ stud extensions Sat, 30 July 2005 05:47 Go to previous messageGo to next message
yea no kidding......
has anyone ever used these stud extensions before??
terrykoun
Re: changing studs/ stud extensions Tue, 02 August 2005 04:42 Go to previous message
anyone?
Previous Topic:4A-GTE Cams Question
Next Topic:KE10 - KP61 front end conversion
Current Time: Sat Oct 17 23:24:53 UTC 2026
Total time taken to generate the page: 0.005713939666748 seconds
