Toymods » Tech & Conversions » Probs. With Firing in 3TC
roids70
Tasmania, Evandale
April 2005
Probs. With Firing in 3TC Wed, 27 July 2005 02:36 Go to next message
right this is really getting on my nerves!! im having probs with it cause its firing on 3 cylinders, well it sounds like it anyway, but its actualy firing on all 4, i've timed it right and everything and i just cant figure it out so if anyone can help i would apriciate it
Cheers Sean
gearb0x
Re: Probs. With Firing in 3TC Wed, 27 July 2005 05:25 Go to previous messageGo to next message
inspected the dizzy cap? replace the cap and rotor, see how that goes, they probably need replacing anyway if you havent allready
replacing the points prolly wouldnt hurt either
bunkyT18
Pilbara
Re: Probs. With Firing in 3TC Wed, 27 July 2005 06:05 Go to previous messageGo to next message
I know this is probly already done but have a look for exhaust leaks and also make sure you have the plug leads on right. You are not being very clear about what is wrong. It sounds like you just don't like the sound of it running and no doubt it also is running like crap but you know it fires on all pots. Is the vac advance on the dizzy ok? Just go through all thwe options and you will track down what the problem is eventually.
Replace as needed all sparky bits from dizzy to plugs... Can't hurt to do it.
Jezza
Re: Probs. With Firing in 3TC Wed, 27 July 2005 07:06 Go to previous messageGo to next message
if you have no luck with fixing up the spark do a comp test, see if the suspect cylinder is low on comp, if it is, squirt a lil oil into the suspect cylinder and retest the comp. if it returns to a better level u have screwed rings, if not, u have a screwed valve or h/g leak
fwiw, i cracked a valve spring in my 2tc, was resting on the edge of the seat the springs sit in, so was idling ok, but once it hit 2000rpm it was missing on that cyl, took some work to figure out Confused
roids70
Tasmania, Evandale
April 2005
Re: Probs. With Firing in 3TC Wed, 27 July 2005 08:46 Go to previous message
i found it!!! one of the exhaust valves was stuck open, dunno how but it just was, so i hit it with a mallet and it freed up,so that got that fixed, idels like a dream now!!
thanx for all your sugestions
Cheers sean
Previous Topic:2jzgte models and sump positions
Next Topic:a\c bracket for 2tgeu
Current Time: Mon Oct 19 17:52:31 UTC 2026
Total time taken to generate the page: 0.0043208599090576 seconds
