Toymods » Tech & Conversions » mid range lag???
Stomps
Canning Vale WA
icon5.gif  mid range lag??? Wed, 27 July 2005 03:07 Go to next message
hey guys, recently did head gasket on 7m-gte (surprise surprise) car is running again all is good but between 5 and 10 psi the car really seems to die in the arse.. after 10 psi it runs great but in that little period it feels laggy as fuck.. it feels like its geting too much fuel, (same sort of feeling if you have a hole in intercooler hose)
any ideas or suggestions would be great. cheers
ke1500
Re: mid range lag??? Wed, 27 July 2005 03:56 Go to previous messageGo to next message
I once changed my inlet/exhaust gasket on my 5k and coz i used too much silicone, when i did the bolts up it squeezed it all together and somewhat blocked the ports. yes i could notice the difference. it was a slug. had to try again.
Stomps
Canning Vale WA
Re: mid range lag??? Wed, 27 July 2005 04:00 Go to previous messageGo to next message
ahh, that could be it, i had the main gasket for the intake manifold but we did use goo in between thetwo sections.. that could be it.. cheers
any other ideas
sxr01r
The Hills District
Re: mid range lag??? Thu, 28 July 2005 10:00 Go to previous message
give the ignition timing a check with a reliable timing light and ull also have to bridge 2 diagnosis wires to drop the idle. i had the same thing on my corolla (well it doesnt have a turbo but you know what i mean) and it used to lag bad with big flat spots then it would pick up again. i then knocked timing forward a little and it was a significant improvement.
Previous Topic:need 18R-GEU info...
Next Topic:boiling 3s-ge
Current Time: Fri Oct 30 14:17:52 UTC 2026
Total time taken to generate the page: 0.045691967010498 seconds
