Toymods » Tech & Conversions » 1jz map sensor wiring
Chris Davey
sunny coast, qld
1jz map sensor wiring Wed, 27 July 2005 10:49 Go to next message
Just wondering if anyone knows which wire is which on a 1jz map sensor. They all seemed to show continuity to ground when the car was off? It is now disconnected. I have a new 3 bar map sensor to wire in. I really only need to know which is power and which is ground. At the link below it shows the turbo pressure sensor on page 2 and it is connecter O. If anyone knows which wire is which that would be great Smile
http://www.1jz-gte.us/documents/SubDocs1/1JZAnalog Gauges.pdf
sideshow
Re: 1jz map sensor wiring Wed, 27 July 2005 11:00 Go to previous messageGo to next message
that file tells u nothing
that turbo moost sensor is not the map sensor for the engine
im pretty sure the 1j have a seperate boost sensor for the gauge
the wires are white orange and another colour
not to sure what the wire colors are for the engine map sensor
if i get spare time over weekend ill chase it up
i think light green with red trace maybe is the signal wire
ithen brown should be sensor earth as thats toyota common colour
and 5volt supply i think is yellow
but if u stuff it its yr fault not mine Smile
Chris Davey
sunny coast, qld
Re: 1jz map sensor wiring Wed, 27 July 2005 11:14 Go to previous messageGo to next message
There is a yellow wire with red stripe
a brown wire
and a white wire (bit dirty)
So going by those colours I would say that brown is ground, white is 5V and yellow with red is signal. What do you reckon? Wink
sideshow
Re: 1jz map sensor wiring Wed, 27 July 2005 11:25 Go to previous messageGo to next message
do u have the right sensor make sure its not the sensor for boost gauge
white might be signal
put a meter on it when ign is on it should have 5 v
wilbo666
Re: 1jz map sensor wiring Wed, 27 July 2005 11:42 Go to previous messageGo to next message
JZX81 wiring diagram I have shows...
Y-R (yellow-red) -> PIN (Signal)
BR (brown) -> E2 (Earth)
W (white) -> VCC
Check that with a multimeter first of course Smile
Chris Davey
sunny coast, qld
Re: 1jz map sensor wiring Wed, 27 July 2005 11:44 Go to previous messageGo to next message
This sensor is next to the igniter in my car. At the back of the inlet manifold on the firewall. I don't think it matter that much as long as it has a 5v and a ground wire going to it. I am wiring in a 3 bar BM map sensor.
I will test it out how you said. Thanks Smile
Re: 1jz map sensor wiring Wed, 27 July 2005 15:32 Go to previous messageGo to next message
pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeease DONT DO IT!!
just get your wolf running the whole lot!! Sad
Chris Davey
sunny coast, qld
Re: 1jz map sensor wiring Wed, 27 July 2005 23:10 Go to previous message
Hey?
I am fitting this one so I can datalog boost properly as my boost controller has been setup to boost as much as it wants. This signal wire will go into the wolf and over ride its 2.5bar map sensor incase I want to go crazy on boost in the future.
I will get the wolf doing timing but I am waiting to get a auto shift controller before I do that Smile
Previous Topic:Tial 38mm external gate options?
Next Topic:import 4age and petrol types
Current Time: Mon Nov 2 18:24:21 UTC 2026
Total time taken to generate the page: 0.0061140060424805 seconds
