Toymods » Tech & Conversions » F Series Diff into KE35
ROTAROLA
April 2005
F Series Diff into KE35 Wed, 27 July 2005 15:11 Go to next message
will it need to be shortened?
what discs/calipers will fit?
what model was this diff from?
how much for 1 approximatly?
what LSD bolt in?
leaf spring?
PCD? same as xt130 corona?
Re: F Series Diff into KE35 Wed, 27 July 2005 23:50 Go to previous messageGo to next message
1. For a KE35, probably.
2. If you get an MS112 Crown diff it has factory discs.
3. MS112 Crown or MX2x Corona MkII. Possible some vans as well (Liteace/Tarago).
4. Depends where you get it from and what mood the toothless wrecker is in. Maybe $100.
5. MA61 Supra or aftermarket (eg TrueTrac torsen).
6. Depends where you get it from. Most are coils though.
7. Depends where you get it from. MS112 is 5x114.3, MX2x is 4x114.3. Not sure about the vans, probably 4-stud though.
ROTAROLA
April 2005
Re: F Series Diff into KE35 Thu, 28 July 2005 08:07 Go to previous messageGo to next message
cheers Norbie for the help.
have a good 1
Blackers
Forrestdale W.A.
Re: F Series Diff into KE35 Fri, 29 July 2005 10:07 Go to previous messageGo to next message
Phil at final drive services in O'Connor is a wizard at shortening diffs and getting mounts changed over, he can also help with your tailshaft issue that you will prolly have. I used him to do my hilux to AE86 conversion and was very happy with the service and workmanship. Hope this helps
Mark
ROTAROLA
April 2005
Re: F Series Diff into KE35 Fri, 29 July 2005 16:29 Go to previous message
cheers for that lil bit of info Mark
that will be handy.
Previous Topic:Decreasing intake restricion
Next Topic:installing water temp gauge
Current Time: Sat Nov 21 04:23:05 UTC 2026
Total time taken to generate the page: 0.004317045211792 seconds
