Toymods » Tech & Conversions » What to do while engine/gearbox is out of car??
rollaboy
Coffs
What to do while engine/gearbox is out of car?? Sun, 15 December 2002 00:51 Go to next message
What would you guys suggest doing to a 4age while out of car??
Should i replace and gaskets/seals???
I have a oil leak around the the dizzy..is that hard to fix??
Thanks Brett
TE72_Turbo
Re: What to do while engine/gearbox is out of car?? Sun, 15 December 2002 08:13 Go to previous message
the leak will just be due to the 'o' ring on the dizzy shaft being fatigued. They often harden & crack after many years of use. pull the dizzy out & take it to a place (most auto shops) that sell o rings, and find one to match the groove in the dizzy. leak solved.
If theres nothing else wrong with the motor, dont worry about changing other unneccessary gaskets! are you planning any mods?
Phil
Previous Topic:Manual 7M-GE RPM limiter
Next Topic:RT104 18RGU accel setup
Current Time: Thu Nov 19 03:31:09 UTC 2026
Total time taken to generate the page: 0.0084159374237061 seconds
