Toymods » Tech & Conversions » 1jz into vk
Mr_X
April 2005
1jz into vk Fri, 29 July 2005 03:41 Go to next message
Hey guys,
been on the commodore form but thought I would get more help here about the 1jz conversion. I was considering an RB25 then discovered that the 1jz comes stock with twin-turbo's has more stock power then the RB and an auto half cut will be cheaper then a RB engine package. Although with all the custom parts (mounts, sump, X-member, tailshaft) it may all add up anyways...
Will any of the VL items work with the 1jz conversion?
LSD 3.45:1 diff?
VL fuel tank?
VL k-fram?
Any extra info would be appreciated
Here is a link of the half-cut
www.japimports.com.au
Cheers.
V8_MA61
Re: 1jz into vk Fri, 29 July 2005 03:47 Go to previous messageGo to next message
yes this has been done before, but i reccomend you dont do it. WHy not go an rb30 bottom end with rb20 head? It will make a lot of power with the right hardware (turbo etc) and the stuff from a VL is interchangeable isnt it??
V8_MA61
Re: 1jz into vk Fri, 29 July 2005 03:48 Go to previous messageGo to next message
i also was referring to interchangeable crossmember and engine mounts etc?
Skip
Re: 1jz into vk Fri, 29 July 2005 04:47 Go to previous messageGo to next message
V8_MA61 wrote on Fri, 29 July 2005 11:47
yes this has been done before, but i reccomend you dont do it. WHy not go an rb30 bottom end with rb20 head??
Quite simple really.
It will cost alot more than a 1JZ conversion
And a stock RB30 will p00h itself at 300rwkw which a 1JZ will happily cope with.
Chris Davey
sunny coast, qld
Re: 1jz into vk Fri, 29 July 2005 05:53 Go to previous messageGo to next message
I would be opting for a 1j over an rb30DET also. Will be a lot cheaper having a stock engine.
I don't see why you couldn't use a VL diff. Just have to get a tailshaft to suit. Fit the yoke from the halfcut onto custom tailshaft and you are set.
I would think the same for the fuel tank. I assume you would use a Vl one because it is EFI. The options are to install a higher flow in tank fuel pump or use the stock VL pump to surge tank and bigger external fuel pump. Either way it is a good idea to upgrade fuel pump.
Re: 1jz into vk Fri, 29 July 2005 06:10 Go to previous messageGo to next message
Warning - troll like actions on Performance Forums.
http://pforums.company-hosting.com/forums/showthre ad.php?s=4fce198e77085703bd65442d58ce289a&t=67 188605
http://pforums.company-hosting.com/forums/showthre ad.php?s=4fce198e77085703bd65442d58ce289a&t=67 187525
http://pforums.company-hosting.com/forums/showthre ad.php?s=4fce198e77085703bd65442d58ce289a&t=67 185695
http://pforums.company-hosting.com/forums/showthre ad.php?s=4fce198e77085703bd65442d58ce289a&t=67 186551
Proceed with caution.
Dust
Re: 1jz into vk Fri, 29 July 2005 06:43 Go to previous messageGo to next message
lol quote from one of those links
in your case?
1. hire car trailer
2. tow vk to nearest qualified mechanic
3. return trailer
4. go home and wait for phonecall
5. return to above mechanic with blank cheque.
6. sign cheque.
7. drive home and do skidz
8. dont die..
told you it was a pretty easy conversion
this quote could be used alot during school holidays and such.
Mr_X
April 2005
Re: 1jz into vk Fri, 29 July 2005 06:45 Go to previous messageGo to next message
gianttomato wrote on Fri, 29 July 2005 16:10
Hey that was a while ago I was assesing all my options I'm not doing that anymore this is for real and I gong to be doing the 1jz in a couple of months so no need for that - gianttomato -
Cheers for the info
Re: 1jz into vk Fri, 29 July 2005 06:53 Go to previous messageGo to next message
Post a photo of you standing next to a VK and a 1JZ frontcut and we might take you seriously. Otherwise, I call troll.
Re: 1jz into vk Fri, 29 July 2005 06:57 Go to previous messageGo to next message
Norbie wrote on Fri, 29 July 2005 16:53
Post a photo of you standing next to a VK and a 1JZ frontcut......
With a sign that clearly states "I like enema fudge".
http://www.419eater.com/images/trophy_room/albert_williams.jpg
[Updated on: Fri, 29 July 2005 07:02]
rb30 boy
July 2005
Re: 1jz into vk Fri, 29 July 2005 09:05 Go to previous messageGo to next message
There is a few thing id like to comment on in this thread.
firstly to answer your question.
YES all vk stuff is interchangable with vl stuff,they share the same floorpan and are basically the same car with exception to he front guards and radiator support panel.
Rb20 heads will NOT bolt upto a rb30 block,rb25(with minor mods) and rb26 will.
An rb30 making 300rwkw will not shit its self.They are extremely strong and should never be under estimated.The only downfall is the heads become restrictive at high revs but they make shitloads of power under 5000rpm anyway.My last sohc rb30 made 250rwkw with ease with only a cam and springs uptop to help the flow.The only reason it didnt make more was that the t04b turbo ran out of puff.
Just because something has 2 turbo's doesnt mean its better than something with 1.The factory turbo plumbing of a 1jz is extremely complicated and i think is a major pain in the ass.
likewise with the exhaust.Dont forget the exhaust of a 1jz is on the same side as the steering in a commodore.its gonna be a tight squeeze down there!
I recommend using a vl crossmember and bolting a rb25 straight in(yes it all fits)and you will be a very happy camper:)
Re: 1jz into vk Fri, 29 July 2005 09:29 Go to previous messageGo to next message
I think everyone knew I'd pipe up eventually?
RB20: toughish, easy to fit, reasonably priced (sometimes!), but need to be treated brutally to go like they should - i.e. they rev out alright, but don't have a lot down low. Not good for doing skidz...
RB25: generally overpriced, and will toss a rod/munch a piston once you start making reasonable power with them unless you rebuild them. And still a bit light own at low RPM.
RB26: I'll mention price and say no more?
RB30: Not likely without a rebuild - any examples you find now are just too damned old, and turbo ones are overpriced anyway.
1JZ: If a fool like me can shoehorn one into an XF, I doubt a VK is gonna be too hard... Do it! Others have done it before and can offer advice on engine mounts etc. Plus you'll be forced to show it to me when you're done...
2JZ: Definately do it if you can find one at the right price. Razz
deesonet
Toowoomba
Re: 1jz into vk Fri, 29 July 2005 10:21 Go to previous messageGo to next message
If you PM me your email address I can send you a complete tech article on fitting a 1JZGTE into a VL Commodore.
Mr_X
April 2005
Re: 1jz into vk Mon, 01 August 2005 06:55 Go to previous messageGo to next message
Sweet just what I need.
PM sent
Cheers.
ripfast
June 2005
Re: 1jz into vk Mon, 01 August 2005 11:07 Go to previous messageGo to next message
mate im doin the conversion at the moment. trust me i did detailed research from rb to 5ltr v8 to 1j. 1j's are fairly cheap, and absolutely shit on the rb. and there is so much room in the vk its not funny. i have mounted mine and there is so much room in the gbox tunnel i can basically hug the box. if you have a efi 202 then you dont need a tank or pump cause its all there already. the vk has 3 different gox mount spots you just use one of them. i just flipped over the vk gbox support and had the holes drilled (easy) and then mount your motor from there, you can slide the motor with the gbox attached straight in theres so much room. the only place there is no room is around the steering column. the rear turbo comes extremely close and the exhaust has to be squeezed passed. Mine was out of a chaser jzx81. i have a rebuilt 4.4 ration LSD 10 bolt salisbury i picked up 750 from the trader. dont rush anything as bargains come and go as you put it together. just cant wait to drop in the fat front cooler and drag a skyline with my 1j in a car that weighs 12ookg Laughing Laughing Laughing
Mr_X
April 2005
Re: 1jz into vk Mon, 01 August 2005 23:38 Go to previous messageGo to next message
Cheers for all the info guys
1gt48u
newcastle
Re: 1jz into vk Tue, 02 August 2005 01:02 Go to previous messageGo to next message
mr_x
send a pm to captain chaos
he is the guy who owns gihook
the green vk with a 1j conversion
I'm sure he could give you a few ideas
cheers Very Happy
dayzii
Perth W.A
Re: 1jz into vk Tue, 02 August 2005 02:31 Go to previous messageGo to next message
rb30 boy wrote on Fri, 29 July 2005 19:05
But RB25s are gay. 1JZ are heaps better. plus you get rid off all that "pain in the ass plumbing" when you change turbos anyway. esp if your after 300kw+
IIRC RB25s are a larger engine in physical size then 1JZs.
ripfast
June 2005
Re: 1jz into vk Tue, 02 August 2005 08:22 Go to previous messageGo to next message
yeah rb 25's are way bigger than the oneJAY and not as much POWER
rb30 boy
July 2005
Re: 1jz into vk Tue, 02 August 2005 10:49 Go to previous messageGo to next message
1gt48u wrote on Tue, 02 August 2005 11:02
mr_x
cheers Very Happy
Lol yeah they're gay. Haha. Thats why my mate is pulling 343rwkw with his unopened rb25
Sorry i quoted the wrong post
[Updated on: Tue, 02 August 2005 10:50]
Re: 1jz into vk Tue, 02 August 2005 11:04 Go to previous messageGo to next message
rb30 boy wrote on Tue, 02 August 2005 20:49
yes yes, they're fully sik...
at what boost and rpm is it making 343rwkw?
rb30 boy
July 2005
Re: 1jz into vk Tue, 02 August 2005 11:45 Go to previous messageGo to next message
lol@fully sik, but im not joking,they are great engines. the combo is rb25 stocko motor,custom exhaust manifold made by me,gt35r turbo@25psi,external gate,big fuel system,cooler,exhaust.
it makes power in an amazing fashon and simply trashes the tires in any gear at any speed.
has run 11.7@117 with the 5 speed/3.45:1 diff and crossed the line still in 3rd gear.we are fitting a 4.11:1 diff and hope to hit the 10's
rb30 boy
July 2005
Re: 1jz into vk Tue, 02 August 2005 11:47 Go to previous messageGo to next message
rb30 boy wrote on Tue, 02 August 2005 21:45
lol @fully sik, but im not joking,they are great engines. the combo is rb25 stocko motor,custom exhaust manifold made by me,gt35r turbo @25psi,external gate,big fuel system,cooler,exhaust.
has run 11.7 @117 with the 5 speed/3.45:1 diff and crossed the line still in 3rd gear.we are fitting a 4.11:1 diff and hope to hit the 10's
grrrrrrrrr mods delete please
[Updated on: Tue, 02 August 2005 11:48]
Re: 1jz into vk Tue, 02 August 2005 13:48 Go to previous messageGo to next message
And RB's rip teh best skidz Razz anyone knows that...
Thing is, a couple of people I know with boosted Skylines (i.e. fulsik cooler, ECU, injectors, exhaust, bigger turbo, etc.) are making quite reasonable power, but they only seem to last for a short time before they're getting an engine rebuilt/another wrecker engine. Seems to be the nature of the beast.
But who am I to say, let's see some of the ultimate JZ vs RB battle on the dyno, and the dragstrip!
Re: 1jz into vk Tue, 02 August 2005 14:33 Go to previous messageGo to next message
mrshin wrote on Tue, 02 August 2005 23:48
Laughing
RB25 vs 1JZGTE vs 4K-C for a full throttle dyno longevity contest!!
Re: 1jz into vk Tue, 02 August 2005 14:48 Go to previous messageGo to next message
oldcorollas wrote on Wed, 03 August 2005 00:33
Laughing
Oh hell yes! I'll bring one of the JZ's, get it producing, say, 10% more power than the 4K flat out, and see who's still going in the morning Razz
Then we'll hit the dragstrip!
Re: 1jz into vk Tue, 02 August 2005 15:05 Go to previous messageGo to next message
ummmm... suuuure Rolling Eyes Rolling Eyes Rolling Eyes i'll see if i can make it next week Cool
i was kinda hoping all three motors would be at WOT.... not dragged down to 4K level Laughing
Re: 1jz into vk Tue, 02 August 2005 15:10 Go to previous messageGo to next message
Actually, it would be kind of fascinating to put my long suffering old 4AG up against an equally well loved old 4K, stick them on an engine dyno, get them going for all they're worth, and see which one falls over first.
But I think we have digressed slightly from the topic!
Chris Davey
sunny coast, qld
Re: 1jz into vk Tue, 02 August 2005 22:37 Go to previous message
Sounds like a very similar setup to SICO1J except his is obviously a 1j not an rb25. Has made 404rwkw on stock internals. AFAIK hasn't been to the strip at that power level though.
Previous Topic:ke20 master cylinder upgrade
Next Topic:keyless entry not working
Current Time: Fri Nov 20 22:54:54 UTC 2026
Total time taken to generate the page: 0.0079660415649414 seconds
