Toymods » Tech & Conversions » clutch for 3t-gte
t18_psi
perth wa
June 2005
clutch for 3t-gte Fri, 29 July 2005 04:43 Go to next message
hey there
im getting a new clutch atm for my t18 3t-gte as it is completely knackered
just after some suggestions as to what kind of clutch to get??
it has a stock t50 gbox in it.
i dont really want a paddle clutch as they arent too friendly for every day driving/ reversing ect. the bloke at the shop rekons ill need something like that tho or the clutch will be destroyed...
any help apreciated.
cheers - lewy
ta2272
Re: clutch for 3t-gte Fri, 29 July 2005 04:53 Go to previous messageGo to next message
he is probly right about the clutch being destroyed as it will slip, expecially wwith a t50 clutch size, thought if you went a button clutch i cant see your t50 lasting very long, i would go with a heavy duty and see how you go.
Jason
Jezza
just get a std organic clutch with a modified pressure plate for extra force, and bigger left leg muscles too Wink
jackel
Re: clutch for 3t-gte Fri, 29 July 2005 05:49 Go to previous messageGo to next message
did you find out how much they would cost, i might need a new clutch for my 3t-gte.
But mines gonna be behind a w55
aeke
Re: clutch for 3t-gte Fri, 29 July 2005 09:06 Go to previous messageGo to next message
I have a sprung puk clutch in my car with a 3tgte and t50, it drives just a little bit more aggressive then standard but still easy to drive. It never slips but I have been through a few gearboxes. I had a heavy duty standard clutch in it but it started to slip after about 2000km's. You will need a W55 if you want reliable car.
thetoyman75
Club President
Re: clutch for 3t-gte Fri, 29 July 2005 09:16 Go to previous messageGo to next message
A sprung centred ceramic is no harder to drive than a H?D Organic in fact it will probably be easier. Don't get confused with the old button style clutches of the early 90's.
You will want to get a decent ceramic clutch if you intend to have anything other than a std 3T-GTE. if your happy with it stock then a H/D organic will do if driven with respect. Keep in mind the factory 3T-GTE clutch was allot bigger than the one in your T-50.
t18_psi
perth wa
June 2005
Re: clutch for 3t-gte Mon, 01 August 2005 03:52 Go to previous message
thanks for the feed back guys
the one that was in it was a sprung 3 puck (ceramic i think)
this slipped when any more than half throttle was used so i figured it needed replacing. upon inspection i found it was worn down to the metal and had carved some nice grooves into the flywheel face - 2 to 3 mm deep!!!
the bloke at brakes west rekoned it had a holden pressure plate. anyone know of a stiffer one to replace it with??
Previous Topic:4AGE injector problems.... HELP NEEDED !!
Next Topic:Waste gate actuator problems
Current Time: Wed Oct 21 02:57:03 UTC 2026
Total time taken to generate the page: 0.0051379203796387 seconds
