Toymods » Tech & Conversions » 4AGE injector problems.... HELP NEEDED !!
panda_levin86
4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 10:21 Go to next message
Hey guys
Just wondering if this had happened to any of you guys before...
The cold start injector is running , while the other 4 main injectors are not... have tested and found out that I am not getting a paulse from the injectors connectors with a node light....
only works on the cold start connector....
anyone knows whats going on?
Re: 4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 11:20 Go to previous messageGo to next message
Interesting....
Is the engine running at this time?
TREO
Melburn
July 2005
Re: 4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 11:36 Go to previous messageGo to next message
is it possible the cold start injector could run 4age, sounds like it wont start. if it is running have you check each injector individually for pulse. basically injectors are mechanical valves that are operated by an electromagnet- it is a type of electrical solenoid. the ecu sends voltage signals to energize the electromagnet in the injector, in turn opens the valve to spray fuel. hope this is some help Wink
ae86drift
sydney.au
Re: 4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 11:53 Go to previous messageGo to next message
CAS wiring?
FASTFOO
melb
February 2005
Re: 4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 14:21 Go to previous messageGo to next message
The cold start will work evern if the computer is missing it is stand alone.
Check if you have 12v at injectors with ignition on.
If you do check the computer earths (should brown wires bolted onto manifold.
hope this helps.
MATT.
Salad Fingers
Darwin, Australia
March 2005
Re: 4AGE injector problems.... HELP NEEDED !! Fri, 29 July 2005 15:21 Go to previous messageGo to next message
Fubar'd ignitor and/or ignitor wiring...
panda_levin86
Re: 4AGE injector problems.... HELP NEEDED !! Sat, 30 July 2005 06:20 Go to previous messageGo to next message
the motor starts now.
but only for a fraction of a secs, then it will die staright away.
checked that there is a paulse for the injectors now..
sideshow
Re: 4AGE injector problems.... HELP NEEDED !! Sat, 30 July 2005 07:41 Go to previous messageGo to next message
for 200 bucks ill come and fix it on sunday hehehehe
TREO
Melburn
July 2005
Re: 4AGE injector problems.... HELP NEEDED !! Sat, 30 July 2005 08:41 Go to previous messageGo to next message
CAS is a definate possibilty!will the car stay on if you manipulate the throttle using accell pedal? have you pullED all the plugs out and had a look at the condition. Smell them and see what they look light, is there fuel on the tips of the plugs, any fouled. This should give you some good indication what area the problem might be in, untill you work that out its going to be hard to work out over a keyboard
cheers hope this helps
sideshow
Re: 4AGE injector problems.... HELP NEEDED !! Sun, 31 July 2005 11:29 Go to previous messageGo to next message
usually if it was cas it would not start
if it has spart cas is ok
check for injetors clicking while crankin
the ecu turns of injetcors if car doesnt start
panda_levin86
Re: 4AGE injector problems.... HELP NEEDED !! Mon, 01 August 2005 01:38 Go to previous messageGo to next message
Okay.....
so this is whats working...
fuel pump... we got fuel pressure.
Good spark and got the timing correct.
and this is not working.
No current to the injector connectors...
all 4 of them.
only on the cold start.
so the engine will start for about 2 secs now, and then it will die off.
bobob
adel
Re: 4AGE injector problems.... HELP NEEDED !! Mon, 01 August 2005 05:04 Go to previous message
Sounds like you are on the right track. This happended to me a while back. Took a few nights but it was some bad wiring in the loom for me, checked many things though..
Heres the link back to when I asked for help:
http://forums.toymods.org.au/index.php?t=msg&t h=68387&rid=8820&S=491c85a2b0263c03c986574 79873c1fc
Good luck Smile
Previous Topic:Crappy ae86 clutch
Next Topic:clutch for 3t-gte
Current Time: Wed Oct 21 02:57:55 UTC 2026
Total time taken to generate the page: 0.0044419765472412 seconds
