Toymods » Tech & Conversions » turbo 4ac
meat axe
melbourne
January 2005
turbo 4ac Sun, 31 July 2005 01:29 Go to next message
my mate has a AE71 rolla that is stock. we are doing some suspension work to it and we got thinking. he just so happens to have some ford ba 6 cyl injectors, a audi tt coupe turbo and efi running gear lying around. we were thinking of throwing it all together with hawk comp that he can get a hold of very easily and cheep. any ideas other than the wiring mess and decomp. how do you recon the 4ac will hold up?
YelloRolla
On your mum!
Re: turbo 4ac Sun, 31 July 2005 01:51 Go to previous messageGo to next message
It should hold up fine - unless you go crazy with boost. Keep it real and enjoy the fairly inexpensive power.
Why would you de-comp it?
Corona RT142
Campbelltown
Re: turbo 4ac Sun, 31 July 2005 01:54 Go to previous messageGo to next message
no need to decomp it most older toyota engines running pretty low compression anyway so are perfect to throw some boost into, and if it dies there are plenty of 4ac's going for free when ppl want to get rid of them
Re: turbo 4ac Sun, 31 July 2005 02:54 Go to previous messageGo to next message
Do it in the name of paddock value, and laugh every time it dies Razz
Otherwise, sell all the bits that are lying around, and buy a cheap 4AG
gearb0x
Re: turbo 4ac Sun, 31 July 2005 04:22 Go to previous messageGo to next message
Even if it doesnt hold up, there are hundreds of free 4ac's out there Smile
I think the hardest part will be your intake manifold, you can do a simple j pipe off the stock exhaust manifold for the turbo, but if you use the stock intake one it will be a bit of work mating a fuel rail and injectors into it
Unless the "efi running gear" you speak off is a manifold of similar port pattern Razz
The other option is put the turbo on a j pipe, remove the stock carby and have it blow right into the intake mani, and use an SU carbie or some sorta suck through on the inlet of the turbo
meat axe
melbourne
January 2005
Re: turbo 4ac Mon, 01 August 2005 06:25 Go to previous messageGo to next message
thanks for all the help. the plan is to fit it all up and get it running on a spare motor that he just got for free Very Happy then drop it in. after we get bored of that i think we way end up treatin it like a cheep whore.... give it as much as we can and make her squeal.
kingmick
Banned by his request
moved to tamworth
Re: turbo 4ac Mon, 01 August 2005 09:22 Go to previous message
like a cheap whore! so your going to treat it with alot of respect and use alot of protection.
mick
Previous Topic:boost controller plumbing
Next Topic:ST141 Corona Info
Current Time: Sat Nov 21 01:12:46 UTC 2026
Total time taken to generate the page: 0.0057170391082764 seconds
