Toymods » Tech & Conversions » 18rg clutch clamp pressure
Scootaphill
Geelong, Vic
18rg clutch clamp pressure Sun, 31 July 2005 08:03 Go to next message
Does any one know what the pressure plate clamp pressure for an 18rg is?
also 18rc(would be intresting to compare)
ALSO
if you have a 18rgT/Z(e) what clamp pressure does your plate have... is it enough? any slippage?
phill
Scootaphill
Geelong, Vic
Re: 18rg clutch clamp pressure Mon, 01 August 2005 00:08 Go to previous messageGo to next message
someone must know.... surly Confused
Scootaphill
Geelong, Vic
Re: 18rg clutch clamp pressure Mon, 01 August 2005 12:30 Go to previous messageGo to next message
last bump!
Re: 18rg clutch clamp pressure Mon, 01 August 2005 22:50 Go to previous messageGo to next message
I think you'll find no-one knows. When people build a serious 18R-G the OEM clutch is usually far from adequate so they get a custom clutch built with lots of clamp. This is certainly what I'll be doing with my 18R-GTE.
Mr DOHC
Re: 18rg clutch clamp pressure Tue, 02 August 2005 09:59 Go to previous messageGo to next message
call direct lutch in brissie, they'll know
or race clutch ion brissie also
Scootaphill
Geelong, Vic
Re: 18rg clutch clamp pressure Tue, 02 August 2005 10:03 Go to previous messageGo to next message
Thanks norbie. what i have been able to find out is the 18R-C motor produces approx 106ft/lb torque and the 18R-G (E)approx 130ft/lb under normal conditions.
However my situation is far from normal as im mating the 18rgeu motor with a kombi box using a VW flywheel modified to suit 18rg, WV clutch and pressure plate. There is a company that makes High Performance clutches for VW (via USA) at a cost$$$. What i've been trying to determine is wether or not an "off the shelf" Heavy Duty VW pressure plate with 25-40% greater clamp force is enough to contain torque that the 18rg will/does produce... considering the clutch surface area is smaller also
So far the answer is yes... right up untill i add a Z or T to the 18rgeu, then its off to USA for a proven high performance clutch and pressure plate
phill
Mr DOHC
Re: 18rg clutch clamp pressure Tue, 02 August 2005 11:06 Go to previous messageGo to next message
when i got my car with the 18RC in it, the clutch had approx 60,000k on it, i didnt change it, now it has approx 70-80,000k on it behind my 18RG, it NEVER slipped, except for once when i slipped it off the line at the drags and it had a small slip from 1-2 shift
Re: 18rg clutch clamp pressure Tue, 02 August 2005 23:25 Go to previous messageGo to next message
I suggest you go to a clutch specialist and tell them what you want, they'll be able to make whatever you need. The 18R-G isn't exactly a torque monster so you won't need anything special.
Mr DOHC
Re: 18rg clutch clamp pressure Wed, 03 August 2005 09:10 Go to previous message
Norbie wrote on Wed, 03 August 2005 09:25
amen to that Rolling Eyes
Previous Topic:Independent Rear Suspension set up for Mark II
Next Topic:toyota wreckers
Current Time: Fri Oct 23 17:31:06 UTC 2026
Total time taken to generate the page: 0.0046560764312744 seconds
