Toymods » Tech & Conversions » 2t Will not idle
dazzlindaly
August 2005
2t Will not idle Mon, 01 August 2005 01:42 Go to next message
mmm i have just put a 2t back in my celica (pulled out the 2tg as it was fucked) anD it will not idle. it will run if you keep the revs up, however as soon as u back off it dies. i have adjusted the idle screw however when i first took this motor out of the car i did not touch the idle screw at all so i dOnt think it has anything to do with it. also right next to the auto choke there is a loose small wire with a male plug end on the enD of it anD i have been told it is because this isnt attached. Does anyone know where this goes, and/or why the car wont idle?
Jezza
Re: 2t Will not idle Mon, 01 August 2005 03:18 Go to previous messageGo to next message
im pretty sure that wire goes to ign+
also check your timing, and whether u have a decent strong spark
dazzlindaly
August 2005
Re: 2t Will not idle Mon, 01 August 2005 06:17 Go to previous messageGo to next message
mm wat/where does it plug into though? and wat does it dO
Jezza
Re: 2t Will not idle Mon, 01 August 2005 06:21 Go to previous messageGo to next message
its an anti-dieseling valve?
basically when it has +12v applied to it, it will open a valve
the valve is there to prevent the engine from idling when the ignition is turned off (without spark) like a hi-comp motor would do
just find a wire which is 0v when ignition is not in the ON position, and is +12v when the ignition is at ON and connect it to that
thats my understanding of things anywho Smile
dazzlindaly
August 2005
Re: 2t Will not idle Mon, 01 August 2005 13:50 Go to previous messageGo to next message
thanks man it fckin workeD, i inspected the motor this arvo anD found it. Did a massive lawn job tonite hehe
Jezza
Re: 2t Will not idle Mon, 01 August 2005 22:06 Go to previous messageGo to next message
no worries mate
enjoy tryin to break the 2t, ive only managed to kill one and crack a valve spring in 5 years Very Happy
dazzlindaly
August 2005
Re: 2t Will not idle Tue, 02 August 2005 08:12 Go to previous message
very nice, but its so gutless, i suppose i am one of the ten thousand other people on here he wants to complain about how shit the jap carby is, haha
Previous Topic:TA22 - Need help from someone with an auto
Next Topic:1jz hydraulic water pump
Current Time: Sun Oct 18 11:54:06 UTC 2026
Total time taken to generate the page: 0.0059418678283691 seconds
