Toymods » Tech & Conversions » soarer power steering pump help
indian
south east - melbourne
soarer power steering pump help Mon, 01 August 2005 01:46 Go to next message
Guys just wondering anyone here know how to bleed the power steering ive filled up with new fluid and added a power steering cooler and ever since that the steering is very heavy , makes a lot of high pitched squeaking when cold while the car is warmed up it doesn’t make any noise any ideas what might have happened , im suspecting air in the system but I have no idea how to bleed it
Any help appreciated
Btw I could be able to control the car with one finger before now its all out the door , any my sis pulsar steers twice as better
Mad Mad Mad Mad Mad Mad Mad
Merudo
Central Coast, NSW
February 2005
Re: soarer power steering pump help Mon, 01 August 2005 02:16 Go to previous messageGo to next message
is the squeaking the belts?
if it is, check the tension of the belts
indian
Re: soarer power steering pump help Mon, 01 August 2005 02:42 Go to previous messageGo to next message
I don’t think it’s the belts , but could be cause it only squeaks when the engine is cold when warmed up its doesn’t make any noise im guessing the power steering fluid is expanding when warm and the air bubbles are reduced
Either way nfi what the hell is happening I just want the steering to be back to normal
My friend told me I need to bleed the system but I dunno how to do it
Re: soarer power steering pump help Mon, 01 August 2005 05:18 Go to previous messageGo to next message
Maybe your cooler is too restrictive and doesn't flow enough when the fluid is cold? What size lines did you use for the return?
indian
Re: soarer power steering pump help Mon, 01 August 2005 05:26 Go to previous messageGo to next message
COOLER IS A FORD FALCON TRANNY COOLER
dunno the size of the lines though but i asked for transmission cooler hose but they are bigger than the cooler outlet i know that as i had to clamp them real hard to seal it properly ,, nothing is leaking too
[Updated on: Mon, 01 August 2005 05:27]
ChuckLandwehr
Re: soarer power steering pump help Mon, 01 August 2005 08:02 Go to previous messageGo to next message
To bleed the Soarer power steering system, you just need to get it on full lock a couple of times. ie. full lock left, full lock right. Might have to do it a few times. Worked when I rebuilt my PS pump.
Find an empty carpark.
cheers Chuck.
indian
Re: soarer power steering pump help Mon, 01 August 2005 08:04 Go to previous messageGo to next message
did all that didnt work for some reason
might have to prop the fron up and do it with no load on the wheels
beggining to shit me now i hate that noise and i hate the heavy steering but i dunno why it works well when its warm
is the cooler too big
off-road
Alice Springs
Re: soarer power steering pump help Mon, 01 August 2005 08:31 Go to previous messageGo to next message
Easiest way to see if cooler is restrictive is to get big hose
(at least 16 mm )and fittings and bypass cooler. If problem goes
away you need a better cooler.
Merudo
Central Coast, NSW
February 2005
Re: soarer power steering pump help Mon, 01 August 2005 09:20 Go to previous messageGo to next message
be careful when bleeding the pwr steering, I remember southo saying that when turning it full lock left, then right, then left, it can SNAP really fast, so be very careful you dont hurt yourself
indian
Re: soarer power steering pump help Mon, 01 August 2005 23:04 Go to previous message
Yeah good idea about bypassing the cooler , will try that soon , I thought it would be ok as it was a ford tranny cooler so I didn’t think tweice about having any problems as if it can cool the tranny it should be good for the power steering
Previous Topic:Decoding the stereo of a 1999 Rav4?
Next Topic:ecu question
Current Time: Sun Oct 18 20:00:10 UTC 2026
Total time taken to generate the page: 0.018086910247803 seconds
