Toymods » Tech & Conversions » External Turbo Oil Leak
sebta22
External Turbo Oil Leak Mon, 01 August 2005 07:37 Go to next message
I have recently been running my new 4agte in the garage and I have noticed under a bit of revs that the nissan t3 turbo is leaking from behind one of the retaining bolts on the turbine housing (connecting the beaing casing to turbine housing). This is leaking and is burning off as white smoke. The turbo is a recon but has been in the garage for a few years.
I am wondering whether the seals have died over the years or whether there is too much oil fed to the turbo.
The restrictor is 1.5mm hole but I tested whether the oil was dumping properly by removing the dump connection near the sump. There seemed to be alot of oil 3-4mm high out of 1/2" line. This seemed to be alot of oil for the turbo. I ran the engine without the connection to sump and it seemed to remove problem but I only ran it for short time because of amount of oil being dumped.
Could it be too much oil being fed and the dump cannot handle it? Would I reduce to 1mm or smaller? There is no pressure in engine as head has breather to air.
Any help would be great
ke1500
Re: External Turbo Oil Leak Mon, 01 August 2005 07:57 Go to previous messageGo to next message
My car had nothing but trouble running a ceramic VG30 roller. From memory, at idle with the oil drain removed, it should flow 500ml of oil every 30 seconds. Make sure there is no more than that. I did this, and it still blew white smoke. And that was with an ATS inspected 2nd hand turbo. Piece of turd.
sebta22
Re: External Turbo Oil Leak Mon, 01 August 2005 13:59 Go to previous message
Did you end up replacing it or recon it??
I amount of oil flowing out of the turbo was about 500ml per 30 secs. I may give it a small drive and see if it still leaks at idle.
Previous Topic:3sgte question
Next Topic:5 speed ke 10 (Driveshaft problems)
Current Time: Sat Oct 17 16:36:45 UTC 2026
Total time taken to generate the page: 0.0057599544525146 seconds
