Toymods » Tech & Conversions » 4AGE ---> KE70
86ONE
August 2005
4AGE ---> KE70 Mon, 01 August 2005 07:54 Go to next message
Can anyone tell me what exactly is envolved to stick a 4AGE into my KE70 Corolla?
As far as i know i only need crossmember from AE71, anything else?
Thanks for any help,
Scott
Gr33nM0nk3y
Re: 4AGE ---> KE70 Mon, 01 August 2005 12:32 Go to previous messageGo to next message
there is alot of information available on this, search for it.
its not a hard conversion..
-bc
Re: 4AGE ---> KE70 Mon, 01 August 2005 12:53 Go to previous messageGo to next message
I've written a few posts on this before, and I'm certainly not the only one. Gravitate towards that little magnifying glass at the top of your screen Very Happy
Big T
Re: 4AGE ---> KE70 Mon, 01 August 2005 13:34 Go to previous messageGo to next message
clutch, pedal box, gearbox just to get you started.
September_Squall
Melbourne, Australia
March 2005
Re: 4AGE ---> KE70 Mon, 01 August 2005 14:13 Go to previous messageGo to next message
yes...
pedal box and clutch master for hydraulic clutch
ae71 or ae86? engine crossmember and engine brackets
gearbox crossmember
22-spline tailshaft
T50 transmission from ae71 or ae86 only
new fuel hoses for efi and high pressure fuel pump
surge tank and lift pump if poss.
new exhaust (or at least splice the two together)
No, it's not hard, I've done similar before and I'm really pretty stupid.
boog
campbelltown
April 2005
Re: 4AGE ---> KE70 Tue, 02 August 2005 01:39 Go to previous messageGo to next message
all you blokes think to much and obviosly havent dont that conversion if the ke70 came with any 4a motor all you need to do is bolt it in no fancy crossmembers or andthing you just lower it in and bolt it in to the standard mounts then get sumone to wire it up not hard at all as long as you are mech minded you wont have a drama. good luck
rthy
Melbourne - NthSubs
Re: 4AGE ---> KE70 Tue, 02 August 2005 02:30 Go to previous messageGo to next message
ke70's came with a 4k motor, and by the looks of things the 4k bell housing is different and so is the crossmember...
the ae71 is pretty much a ke70 with a 4ac + t50
i have bought a 4age that was in a ke70, the running gear had been replaced with ae71 struts with ae86 disk brakes, a ae86 crossmember, ae86 steering rack & t18 rear end. im pretty sure it had a t50 of somekind (not sure from a ae71 or ae86), anyways its all been replaced...
i dont see how a k50 will fit the 4a unless someone has done it before or modded the k50 bellhousing or something, such a small gearbox Confused
i had a 1985 ke70 with a hydraulic clutch in it, but i have seen some with the old skool wire version in older ke70s (82-83)
Re: 4AGE ---> KE70 Tue, 02 August 2005 02:44 Go to previous messageGo to next message
boog wrote on Tue, 02 August 2005 11:39
Quote of the year
ke382TG
Re: 4AGE ---> KE70 Tue, 02 August 2005 02:57 Go to previous messageGo to next message
Quote:
Quote of the year
Scariest thing is this:
Quote:
Occupation: mechanic
Shocked
rthy
Melbourne - NthSubs
Re: 4AGE ---> KE70 Tue, 02 August 2005 03:09 Go to previous messageGo to next message
i remember a mobile mech that came to tune my 4ac for rwc, he looked at the 4ac and said, "my god, somekind of rwd corolla engine..." mind u he had 30years in the field Rolling Eyes
September_Squall
March 2005
Re: 4AGE ---> KE70 Tue, 02 August 2005 03:25 Go to previous messageGo to next message
The KE70 did not come with an A motor. K in KE70 denotes K motor which uses different crossmember, transmission, cable clutch in place of hydraulic, and other differences.
I have done an engine conversion in my KE70 and do understand what is involved. Your advice reflects the fact that you don't really know what you're talking about.
mrshin wrote on Tue, 02 August 2005 12:44
Quote of the year
Ditto.
[Updated on: Tue, 02 August 2005 03:26]
86ONE
August 2005
Re: 4AGE ---> KE70 Tue, 02 August 2005 04:47 Go to previous messageGo to next message
Thanks for replying with some decent, useful answers.
I did use the search function and found out that more than just a crossmember is needed for the conversion.
My guess is that the total cost would be between $1500 - $2000. (?)
I was thinking about just converting to a bigger engine from the K series... 5K (1.5L or 1.6L?) or 7K (1.8L or 2L?)... but would the time and $ be worth it? I was quoted $300 - $400 for a 5K and $1300 for an EFI 7K (i was told this 1 is 2L).
Any thoughts?
Thanks,
Scott
Re: 4AGE ---> KE70 Tue, 02 August 2005 04:53 Go to previous messageGo to next message
7K is 1.8L (ahh google is a wonderful thing)
block is wider and deeper than the 5K, so 7K may not bolt in
86ONE
August 2005
Re: 4AGE ---> KE70 Tue, 02 August 2005 05:08 Go to previous messageGo to next message
Eh, that's interesting and annoying.
The mechanic at alljap told me its 2L and would bolt right in... Rolling Eyes
September_Squall
March 2005
Re: 4AGE ---> KE70 Tue, 02 August 2005 15:20 Go to previous messageGo to next message
Don't confuse wreckers with mechanics. I don't even trust mechanics, and wreckers are often those who came up short on the intelligence and skills to be mechanics.
Re: 4AGE ---> KE70 Tue, 02 August 2005 15:32 Go to previous message
86ONE wrote on Tue, 02 August 2005 15:08
well, at least you know never to shop there again....
Previous Topic:keyless entry not working
Next Topic:identify this valve!
Current Time: Sat Oct 24 06:39:49 UTC 2026
Total time taken to generate the page: 0.0065910816192627 seconds
