Toymods » General Car Talk » what car had original 4agze?
Speed Demon
what car had original 4agze? Tue, 04 June 2002 03:38 Go to next message
This might sound like a stupid question....but what Toyota had the original 4A-GZE engine in it as standard?
I've been fed different information....but i always thought it was an early model MR2 like the AW11.
One more question.....which toyota has the best, affordable variation of the 4agze (MAP sensor type)?
Again, these are probably simple questions to answer...but i haven't been able to get one good straight answer yet.
Norm
Re: what car had original 4agze? Tue, 04 June 2002 03:44 Go to previous messageGo to next message
I do believe that the 4AGZE came in the AW? MR2's and also in AE92's and AE101's, and probably some more too.
But non of theses were released into australia with the 4AGZE form factory, as far as i know anyway.
Hope that helped you in some way.
Cheers Norm.
Darola
Taree, 4h nth of syd
Re: what car had original 4agze? Tue, 04 June 2002 10:29 Go to previous messageGo to next message
the gze came out first in the mr2 aw11 then the ae92's and ae101 levin and tureno's, none of witch where avaliable in australia, most ppl i know of have used the ae92 engine, the 101 engine is map and alot better tho, ive just put the 101 gze into mine, halfcut cost me $3000 form sss
the 101 engine has 30kw over the 92 engine, due to different manifolds and cams, the 101 also has a steal crank, forgged pistons, and steal conrods, the block is very nice and strong and can handle alot, im putting the bigger supercharger on my car and also the pully kit so i would be running 20psi, dont need to do anymods to the internals as the engine can handle it
Speed Demon
Re: what car had original 4agze? Wed, 05 June 2002 07:58 Go to previous messageGo to next message
doesn't the ae92 4agze come out as MAP sensored?
Darola
Re: what car had original 4agze? Thu, 06 June 2002 13:57 Go to previous messageGo to next message
yes the ae92 came out as map, but only the last of them tho, so just check it out before u get one if u r geting the ae92 4agze
Speed Demon
Re: what car had original 4agze? Tue, 11 June 2002 07:53 Go to previous message
so does this mean that they are fairly rare?
The only reason i wanna get the ae92 version is becuase it's a lot cheaper for a half-cut.....i've seen them go for $1800...
Previous Topic:All Toyota Day 2002
Next Topic:urgent..
Current Time: Fri Nov 20 02:01:40 UTC 2026
Total time taken to generate the page: 0.041264057159424 seconds
