Toymods » Tech & Conversions » 4agze Throttle Body??
sicsx
4agze Throttle Body?? Mon, 16 December 2002 00:49 Go to next message
Hey People..
I was just wondering weather someone has put a bigger throttle body on a GZE?? I rekon there is some Kilowatts to free up there.. what do u rekon?? It looks like a SR20 one would fit.
Sicsx
sicsx
Re: 4agze Throttle Body?? Mon, 16 December 2002 04:26 Go to previous messageGo to next message
Here i'll help u guys along i've been doin some research and i found that u may be able to have the 4agze throttle bodys internal diameter machined out to match a N/A 4age throttle body! You can then use the 4age butterfly plate from inside its throttle body and screw it onto the bar inside the 4agze. Very inexpensive, very worthwhile. MAchineing is pretty cheap as far as i under stand!
What do u think??
Sicsx
DAMO
MELBOURNE
Re: 4agze Throttle Body?? Mon, 16 December 2002 08:18 Go to previous messageGo to next message
Yeh, I've put a VN dunnidore throttle body on mine but I don't know the results as yet.
sicsx
Re: 4agze Throttle Body?? Tue, 17 December 2002 00:10 Go to previous messageGo to next message
Sweet.. did that bolt straight on?? or did u have to modify it a little.. and how come u dont know the results?? u havent got it runnin yet??
Let us know
Sicsx
[Updated on: Tue, 17 December 2002 00:11]
DAMO
MELBOURNE
Re: 4agze Throttle Body?? Tue, 17 December 2002 03:03 Go to previous messageGo to next message
No it didn't fit straight on. It required a pipe to be made to locate the throttle body in a different location. This would not work if your using standard computer unless you change TPS etc. My engine died before I could take it out for a thrashin. Let you know next year I hope.
sicsx
Re: 4agze Throttle Body?? Tue, 17 December 2002 04:24 Go to previous messageGo to next message
cool .. that would be good.. i knew the TBS would be a problem.
Sicsx
Ben Wilson
Re: 4agze Throttle Body?? Tue, 17 December 2002 21:40 Go to previous messageGo to next message
There are much bigger restrictions int he ZE inlet system than the throttle body. Have a look inside the supercharger outlet pipe, of the pipe that feeds the inlet manifold. A bigger throttle body isn't going to make much difference unless you also enlarge these parts.
sicsx
Re: 4agze Throttle Body?? Tue, 17 December 2002 22:14 Go to previous messageGo to next message
ohh yes.. i have been reading about that.. but its all good to critisize .. but can u offer any solution to this.. it looks like a big job to fix??
Sicsx
feral4mr2
Bundaberg, Qld.
Re: 4agze Throttle Body?? Wed, 18 December 2002 05:51 Go to previous messageGo to next message
i totally agree with you there Ben, the ze inlet system sux!!!
i would think you could take off the inlet manifold, and die grind it out (i have spent many hours looking at the set-up). then make up a complete new plate and larger diameter pipe work to bolt on...
as for the smaller dia. s/c piping etc. i spose if you wanted to spend some money, you could get all larger dia. pipe work done for it too...
just some idea's..Smile
or just put on a ge inlet manifold, ge throttle body, and turbo it...Evil or Very Mad
Smile
sicsx
Re: 4agze Throttle Body?? Wed, 18 December 2002 06:39 Go to previous messageGo to next message
Cheers ok.. I have redone the pipework on the outlet of the i'c to the inlet pipe of the manifold..and picked up a bit more flow.. but i think your talkin from then on.. arent u??
Sicsx
PS Dont worry if i had a bit more money i would turbo it.. since it just bolts on.! Very Happy
feral4mr2
Bundaberg, Qld.
Re: 4agze Throttle Body?? Wed, 18 December 2002 08:00 Go to previous messageGo to next message
Freakyes, i'm also talking about the pipe that bolts directly to the inlet manifold, the one with the cold start injector on it...
it has a damn small opening (or restriction) depends which way you look at it...Smile
i would look into die grinding the inlet manifold itself out bigger on the top plate, i have looked at it, and i think it can be done...
using the 2 original bolt holes on the passenger side of it, and then you would need to get 2 new holes drilled and tapped on the drivers side of it...
there is a lot of space to be opened up on the inlet manifold... then you could either modify the pipe, or make another one (preferable), with a mount for the cold start injector....
i hope this makes sense??, as i am inbetween the computer and doing a few mod's on my car..Evil or Very Mad
sicsx
Re: 4agze Throttle Body?? Thu, 19 December 2002 00:46 Go to previous message
Yea that makes sence .. cheers.. i will look into this!!
Sicsx
Previous Topic:ze gearbox oil seals
Next Topic:RT104 Brake upgrade
Current Time: Fri Nov 20 21:43:12 UTC 2026
Total time taken to generate the page: 0.0062310695648193 seconds
