Toymods » Tech & Conversions » 1989 cresta info needed
89cresta
August 2005
1989 cresta info needed Mon, 01 August 2005 11:36 Go to next message
after some info about my 1989 cresta.
what type of lsd are used in them and what ones can be put into them?
What type is the standard manual gearbox and how much power can it handle?
What coilovers from other toyota models can be easly fitted in the car or are there ones available for them.
Re: 1989 cresta info needed Mon, 01 August 2005 22:47 Go to previous messageGo to next message
What is the model code for your Cresta?
I'm pretty sure it's the same chassis as the Cressida/Chaser/MkII so the mechanicals will be much the same. This means G series diff, so a wide range of OEM/aftermarket LSD centres are available. If your car has an LSD already it will be a clutch type, same as the MA70 Supra.
As for the transmission, it depends which engine you have. 7M-GTE or 1JZ-GTE will have an R154 5-speed, otherwise it will be a W58 5-speed.
JXZ81 Chaser coilovers should be a direct fit. Try talking to John at ImportBitz, he should be able to source some for you.
EvilJack
Sutho/Hills NSW
Re: 1989 cresta info needed Tue, 02 August 2005 03:31 Go to previous messageGo to next message
http://www.jzx81.net/
some info here regarding different brands of LSD, coilovers etc.
Re: 1989 cresta info needed Tue, 02 August 2005 04:09 Go to previous messageGo to next message
If its an LX80 then nothing rear suspension/diff wise is compatible from other models.
Front suspension only.
Re: 1989 cresta info needed Tue, 02 August 2005 04:21 Go to previous messageGo to next message
Ah yes true, the diesels have a live axle for some reason.
barned01
Re: 1989 cresta info needed Tue, 02 August 2005 08:09 Go to previous messageGo to next message
rear diff being a g series that would fit into a hilux casing????
89cresta
August 2005
Re: 1989 cresta info needed Tue, 02 August 2005 11:44 Go to previous messageGo to next message
thanks for the response.
it is a gx81 series
it only has the 1gfe engine in it put i will soon change that to a 1ggte.
I just wanted to make sure i have lsd coilovers and such first. plus i just found out how big the damn front springs are they are huge! so i want to get coilovers soon so i can get some mags that don't foul with the strut.
Re: 1989 cresta info needed Tue, 02 August 2005 11:48 Go to previous messageGo to next message
The rim doesnt come close to the spring dude.
The spring is higher than the tyre.
And you'll be much better off getting a JZX81 cut.
Re: 1989 cresta info needed Tue, 02 August 2005 23:30 Go to previous messageGo to next message
Agreed. A 1G-GTE will be an improvement but still pretty ordinary. You'll get a much better result with a 1JZ-GTE and if you can source a JZX81 front cut it will be no harder to install.
89cresta
August 2005
Re: 1989 cresta info needed Wed, 03 August 2005 11:15 Go to previous messageGo to next message
would i be able to use the standard jzx81 computer. would it run all the stuff in my car?
Re: 1989 cresta info needed Wed, 03 August 2005 15:06 Go to previous messageGo to next message
Yes, standard JZX81 ecu.
And define what you mean by 'all the stuff in your car'
89cresta
August 2005
Re: 1989 cresta info needed Wed, 03 August 2005 21:37 Go to previous messageGo to next message
my plan would be a straight engine swap so i would want the standard computer from the front cut i get to run in my car with no problem. So "all the stuff" in my car still works like the climate control.
Re: 1989 cresta info needed Wed, 03 August 2005 23:13 Go to previous messageGo to next message
The engine ECU runs the engine and nothing more. Climate control and "all the other stuff" is completely separate.
89cresta
August 2005
Re: 1989 cresta info needed Thu, 04 August 2005 07:35 Go to previous message
thanks for all your help i think i have all the info i need for now
Previous Topic:2JZ-DIFF
Next Topic:Help on conversion from auto to manual
Current Time: Thu Oct 15 07:45:36 UTC 2026
Total time taken to generate the page: 0.064283132553101 seconds
