Toymods » Tech & Conversions » To 18R-G or not
choofa
St. Kilda
August 2005
icon6.gif  To 18R-G or not Tue, 02 August 2005 00:03 Go to next message
Just bought toyo hilux tray top 18R engine and stoopid column shift.Want floor shift so another gearbox is the go.Question is, is it worth putting in 18R-G at same time.Is it a bolt in or is it a fuck around.What do they cost and what is the power diff.
Re: To 18R-G or not Tue, 02 August 2005 00:53 Go to previous messageGo to next message
The 18R-G has substantially more power than the 18R, but it's not really suitable for a light commercial. You might be better off sourcing a torque-monster 22R.
YelloRolla
On your mum!
Re: To 18R-G or not Tue, 02 August 2005 01:03 Go to previous messageGo to next message
Power is a LOT more - but still boring.
It is a bolt-in, that is it will bolt to the same engine mounts and if you use the W50 5 speed it will bolt to the same gearbox cross member (you will need the Celica rubber geabox mount to marry the two). You will need to cut the hole in the trans tunnel for the shifter.
If you are using the EFI (18RGEU) then the brake lines (at the master) will foul with the plenum chamber - some re-bending will give them enough clearance. If you are using the carby model then I am unsure of clearane issues in that area.
You will need to get the exhaust done as it won't bolt up (and nor would you want it to if it's stock).
The tail shaft etc all fits up.
It will still get caned by a VN Confused
For the effort - and ALL engine conversions require lots of effort - I would go 1G GTE.
P.S If you want floor shift, they use the same gearbox with a different side plate. Get the side plate from a floor shifted version of the same model, cut a hole in the floor and you will be floor shifting like a pro.
choofa
St. Kilda
August 2005
icon6.gif  Re: To 18R-G or not Tue, 02 August 2005 01:33 Go to previous messageGo to next message
not racing but want to keep up with traffic when loaded and thanks for the info.by the way.would my memory be right in thinking ford rims fit ?
choofa
St. Kilda
August 2005
Re: To 18R-G or not Tue, 02 August 2005 01:34 Go to previous messageGo to next message
you got any info on the 22g
Corona RT142
Campbelltown
Re: To 18R-G or not Tue, 02 August 2005 01:42 Go to previous messageGo to next message
22r or 22re see sig for power and reliability, peak was at around 4.1krpm, peak torque of 198NM at 2800rpm.
Not a powerhouse, but plenty of torque good roll on acceleration and damn hard to kill. Likes to drink fuel though.
choofa
St. Kilda
August 2005
Re: To 18R-G or not Tue, 02 August 2005 01:57 Go to previous messageGo to next message
will the 22r bolt straight in.dont need a complicated job just a bolt in while gearbox is getting changed[maybe]
YelloRolla
On your mum!
Re: To 18R-G or not Tue, 02 August 2005 03:01 Go to previous messageGo to next message
Ford rims do bolt straight up.
Corona RT142
Campbelltown
Re: To 18R-G or not Tue, 02 August 2005 03:03 Go to previous messageGo to next message
YelloRolla wrote on Tue, 02 August 2005 13:01
what what what
Re: To 18R-G or not Tue, 02 August 2005 03:35 Go to previous message
PCD is the same but centrebore is different.
Previous Topic:Gearbox to fit in 4ag3silver ae86?
Next Topic:help . ke20 diff and front brakes upgrade
Current Time: Wed Oct 21 03:47:46 UTC 2026
Total time taken to generate the page: 0.043230056762695 seconds
