Toymods » Tech & Conversions » 1JZ Water Pump & Timing Belt Replacement - Urgent help reqd
JZZ30MAN
1JZ Water Pump & Timing Belt Replacement - Urgent help reqd Mon, 16 December 2002 05:13 Go to next message
Had a nightmare of a weekend when I went to change my water pump on the 1JZ, realising that I will most likely have to remove the harmonic balancer and do the timing belt at the same time etc.
Not good timing seeing I need the car for x-mas and I only have next weekend to do the job. Want to make sure I have all necessary parts and tech info. Looks like there may be a few o-rings needed for water pump, not sure about all the necessary tensions, ensuring timing belt is installed correctly etc.
I've also seen some threads where people say the water pump is connected to somthing hydraulic, as fluid runs out when removed. Or is this just 1JZ's when they have thermo fans?
If you have any information it would be appreciated.
JZZ30MAN
Re: 1JZ Water Pump & Timing Belt Replacement - Urgent help reqd Fri, 20 December 2002 02:57 Go to previous message
If anybody is looking for help on this topic in the future look for same topic in Australian Lexus Soarer Website, or talk to Luke Sheerman on this website.
Michael
Previous Topic:TA-23 Where to start
Next Topic:Celica 5 speed into a st141
Current Time: Fri Nov 20 21:22:24 UTC 2026
Total time taken to generate the page: 0.0043160915374756 seconds
