Classifieds » Miscellaneous » *****Throttle Bodies*****
7mgtema71
*****Throttle Bodies***** Mon, 16 December 2002 05:34 Go to next message
50mm quad throttle bodies $1200
- Webber style
- Twin injectors on each port
- Comes with eight VL turbo injectors (3mths use)
- Complete with fuel rail and hoses all connected
- Has fitting for a TPS
- It comes with a custom plenum from a previous turbo setup
- Ready to just bolt on EFI
- Might consider separating the injectors for the right price (eg. sell two sets of four)
- In Adelaide
- Reason for sale, “abort project” Sad
Call me on 0438 827 504 or mail me on supra7mgte@hotmail.com
YOGI8U
up yours!
Re: *****Throttle Bodies***** Mon, 16 December 2002 07:16 Go to previous messageGo to next message
what does it fit?
7mgtema71
Re: *****Throttle Bodies***** Mon, 16 December 2002 23:54 Go to previous messageGo to next message
It's a webber design like most throttle carbies so it'll bolt onto and manifold with webber characteristics (eg. most twin carbie setups like 2tg, 18rg and i'm sure the 4age setup, but can't guarantee). I can provide dimension's if your surious. But a manifold's are easy to get made these days.
scottee78
perth
Re: *****Throttle Bodies***** Tue, 17 December 2002 04:41 Go to previous messageGo to next message
what are the injectors? either what vehicle origonaly or ND p/n?
scottee
edit: just spotted the VLt bit, are they numbered though?
[Updated on: Tue, 17 December 2002 04:42]
gabe
Re: *****Throttle Bodies***** Tue, 17 December 2002 04:48 Go to previous messageGo to next message
scottee78, is that your supra in midland?? if it is nice car and how much do u want for it?
7mgtema71
Re: *****Throttle Bodies***** Tue, 17 December 2002 05:06 Go to previous messageGo to next message
I don't know what numbers they are. I can check them out tonight if you want. All i was told was they are VL turbo injectors which were purchased brand new and only had 3 months use on them.
scottee78
perth
Re: *****Throttle Bodies***** Tue, 17 December 2002 07:24 Go to previous messageGo to next message
gabe : usually parked at coventry's? ta, needs some work n tidyin up, just pulled it off the road to go nuts so not for sale sorry Very Happy or 20k if you really want it Razz
7mgtema71: if you have time please Very Happy not sure on the specs of them so with the p/n i should be able to check it out n see if i can use them
scottee
7mgtema71
Re: *****Throttle Bodies***** Wed, 18 December 2002 23:03 Go to previous message
I tried last night to pull out the injectors but it requires all the injectors to come out together and i don't want to pull too much of it apart, but i did notice a "RAM" and "B 6" on all of them if this helps.
They are the marone/dark red coloured tops and are from the holden vl turbo model commodore. They should be at least 450cc each and there are eight so there's plenty of fuel for any four banger, unless your running a t88.
There's lots you can do with this setup like run one set of four at low boost and the other at high boost, nitrious, etc, etc.
Previous Topic:JZA80 TRD 10K RPM Tacho
Next Topic:Bosch Fuel Pump
Current Time: Fri Oct 16 12:04:00 UTC 2026
Total time taken to generate the page: 0.0049049854278564 seconds
