Classifieds » Miscellaneous » Delco EFI
7mgtema71
Delco EFI Mon, 16 December 2002 05:36 Go to next message
Delco EFI computer from JE model Camira $500
- ECU and loom is complete
- Most sensors (all necessary ones). Some are new!
- Never been used since removal from orig Camira
- Sourced out a cable to connect between a laptop and the ECU for on board tuning
- Will provide software too (never tested so no guarantee)
- It’s amazing how versatile the Delco EFI setups really are and at half the price
- Easy way to upgrade an old, already established EFI setup or a good upgrade from the ‘ugly’ carbie setup!
- In Adelaide
- Reason for sale, “abort project” 
Call me on 0438 827 504 or mail me on supra7mgte@hotmail.com
7mgtema71
Re: Delco EFI Thu, 19 December 2002 22:28 Go to previous messageGo to next message
Bump...
If your worried about what everybody else has said about the delco efi, don't listen to them as almost everyone i've spoken to who bagged the setup never had the complete setup in the first place (eg, running without TPS and/or MAP sensors causing the ECU not being aware of whats exactly is going on). Also they never had the right tools for tuning too.
You can ask me questions and hopefully i'd ne able to answer most for you.
Remember, if your in dought, just ask.
I'm negotiable on the price too.
Frank
._T_.
Re: Delco EFI Fri, 20 December 2002 03:34 Go to previous messageGo to next message
frank,
1stly, you cannot just plug a cable into the delco 808 chipset and reprogram it - you have to remove the chip from it and erase/reprogram it.
kalmaker do an emulation board for the delco which will allow you to reprogram their chip - but the software is very complex. perhaps you are selling one of these setups?
there is free 808 software available for the delco - efilive etc.
ps last camira/delco ecu loom setup i had i sold for $150
T
7mgtema71
Re: Delco EFI Fri, 20 December 2002 04:13 Go to previous messageGo to next message
I've done some research on the unit and the section where you obtain the errors codes from on the loom, you tap into it with a cable where on the other is a std serial db9 connector.
From this your able to program while in car without removing the chip and the better the software, the better the tuning capability. I haven't attempted this yet, but others have and have been successful. Just an easier option than removing the chip everytime.
And as i said, i'm negoitable on the price...
Frank
7mgtema71
Re: Delco EFI Fri, 20 December 2002 04:18 Go to previous messageGo to next message
Frank
Grega
melbourne.victoria.austra...
Re: Delco EFI Sun, 22 December 2002 19:55 Go to previous messageGo to next message
hey frank.
the 1227808 used in the camira/pulsar/vn is not able to be programmed (without kalmaker anyway). sure you can download the diags ect - and have a look at them with a simple rs232 cable connected to the ALDL - but you can't make changes on the fly.
the later VR/VS delco ECU's you can make changes on the fly but you need a different cable to connect to the ECU - using a MAX232 chip - um, you can make the changes while you're in the session - but once you make those changes and switch the car off they're gone. you can't write to the ECU permanently.
nonetheless still a very good ECU. considering kalmaker retails for about $995 and a Haltech E6GM (plug in replacement for 1227808 ECU is the same - i know which way i'd be going)
[Updated on: Sun, 22 December 2002 19:55]
roadrunner
Hornsby, Sydney
Re: Delco EFI Mon, 23 December 2002 10:05 Go to previous messageGo to next message
the camira injection is a good set up however the computers always short. hence "crazy delco disease"
Grega
Re: Delco EFI Mon, 23 December 2002 19:25 Go to previous messageGo to next message
RR - can you be more specific - where do they short for example? can't say as i've heard of this...
7mgtema71
Re: Delco EFI Mon, 23 December 2002 21:53 Go to previous messageGo to next message
Me neither! The only way they can short out would be the result of dodgie wiring...
roadrunner
Hornsby, Sydney
Re: Delco EFI Wed, 25 December 2002 02:46 Go to previous messageGo to next message
im not exactly sure. i know its the computer. i think the solder on the electrical terminals on the comp. this has never happenned to me and is just something ive been told as i investigate the system by a couple of people. not really sure how reliable these two guys would be. even though if it is ture how hard is it to pick up a camira comp.
[Updated on: Wed, 25 December 2002 02:49]
Grega
Re: Delco EFI Thu, 26 December 2002 20:33 Go to previous messageGo to next message
not hard at all - less than $50 for camira ECU - can get a VS ECU for $100 at wreckers..
RA28
Re: Delco EFI Sat, 28 December 2002 11:29 Go to previous message
the "Mad delco disease" was covered in zoom a while back, they thought it was caused by thechips comming away from the board, duy to shoddy construction. they said if it does it, just open it up and resolder the chips onto the board, should fix it...
Tim.
Previous Topic:Junk for sale
Next Topic:fs:ae101 cluster
Current Time: Mon Oct 19 15:48:57 UTC 2026
Total time taken to generate the page: 0.0060319900512695 seconds
