Toymods » Tech & Conversions » air-con re'gassing question
gene
icon6.gif  air-con re'gassing question Mon, 16 December 2002 06:29 Go to next message
Hi! Smile.
I need to get my air conditioning regassed if i want to survive this summer... Cool I have a 1982 TE71 Toyota Trueno. I was told that i need to change to a new kind of gas? Is this relativly straight forward, or do i need to change parts, etc?
Also, if anyone could recommend a place in melbourne (preferably in the east somewhere) i would be very grateful!
thanks!
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon3.gif  Re: air-con re'gassing question Mon, 16 December 2002 06:38 Go to previous messageGo to next message
You don't have to convert. You can try to find a place that still has the old gas...
gene
Re: air-con re'gassing question Mon, 16 December 2002 06:44 Go to previous messageGo to next message
hmmm, in that case should i try and look for a place that will put in the old gas? or should i might as well upgrade?
SupraBOY
Yeppoon/Rockhampton
Re: air-con re'gassing question Mon, 16 December 2002 06:51 Go to previous messageGo to next message
old gas is illegal apparently.
all that should be needed is to do minor modifications to your air con gear and all will be happy..... so i'm told with my air con on my 84 supra. i was told it wasn't going to cost more than $100, gas, labour, parts, etc.
gene
Re: air-con re'gassing question Wed, 18 December 2002 03:33 Go to previous messageGo to next message
righteo, thanks fellas...
hmm can anyone recommend a place in melbourne?? SE area prefered.... Smile
haggis
Re: air-con re'gassing question Wed, 18 December 2002 06:06 Go to previous messageGo to next message
Be carefull when changeing to new gas. Depending on the new type of gas (there are more than one) you may need to change every rubber component in the AC system, as some new gasses will eat the seals designed for the old gas.
It pays to ask ahead of time.
Craig.
Pumpkin
Toymods Board Member
Re: air-con re'gassing question Wed, 18 December 2002 21:46 Go to previous messageGo to next message
Stick with the old gas.. R12.. It's colder and more efficient.. The new gas R132? is good, but not as good.. I'm getting mine done with the old.
Correct. But house hold aircon systems still use it.. !!
rvrolla
Central Coast
Re: air-con re'gassing question Thu, 19 December 2002 02:02 Go to previous messageGo to next message
My old Corolla had the old gas, and it was much colder than my new car (the soarer has been converted to the new crap).
I had an air-con place check it out and they just topped it up for me for free Very Happy
Apparently they just keep the gas in a bottle from when they upgrade customer cars to the new gas.
ZZT231
melbourne.vic.au
Re: air-con re'gassing question Thu, 19 December 2002 04:12 Go to previous messageGo to next message
I had MA61 Gas recharged 2 times because when they filled my system up with R12 Gas (old gas) the seals were still leaking even though they replaced all the o-rings especally for the R12/13 Gas (approx 12 on the Celica Supra). Since my system had the new O-Rings they took the R12 and placed the R13 Gas (New Gas) in my system as well as fixed the Leak (by placing 2 o-rings on the leak). I haven't had any problems or leaks (to my acknoledgement).
Hope it helps.
Cheers.
libby
Re: air-con re'gassing question Fri, 20 December 2002 06:59 Go to previous messageGo to next message
I was quoted $250 to get the celica converted to the new gas! Shocked
Bugman
Re: air-con re'gassing question Fri, 20 December 2002 07:14 Go to previous messageGo to next message
Pumpkin wrote on Thu, 19 December 2002 08:46
Thats correct, but any new instillations can't be done with a banned refrigerant such as R12, if you get a leak you are meant to convert it over so that eventually there will be no more CFC refrigerants.
Pumpkin
Re: air-con re'gassing question Fri, 20 December 2002 07:51 Go to previous messageGo to next message
Ok ... you win..
faulksy
Re: air-con re'gassing question Fri, 20 December 2002 08:03 Go to previous messageGo to next message
ZZT231 wrote on Thu, 19 December 2002 14:42
I had MA61 Gas recharged 2 times because when they filled my system up with R12 Gas (old gas).
they should have put i dye in the gas so u could tell where the leak was coming from
ZZT231
melbourne.vic.au
Re: air-con re'gassing question Fri, 20 December 2002 09:04 Go to previous messageGo to next message
faulksy wrote on Fri, 20 December 2002 19:03
I am sorry for the "English" but i thought i said that they replaced the seals intitally. And yes the did the dye and yes they found it. That is why they added 2 o-rings to the leaking connection so the gas could not excape.
Cheers.
gene
Re: air-con re'gassing question Sat, 21 December 2002 07:29 Go to previous messageGo to next message
hmmm well, it's too hot to be driving around without an AC, and i'm a bit short on funds... Razz
think i'll just drive it at night... and drive the 300zx during the day Razz
Rolla Boy
Club Member
Sydney, NSW
Re: air-con re'gassing question Sun, 22 December 2002 00:33 Go to previous messageGo to next message
They do... You just need the special kit for it... We have one at work and it looks cool...
absurd
Re: air-con re'gassing question Sun, 22 December 2002 14:20 Go to previous message
well hello all
being a qualified a/c fitter i may be able to help.
the old gas r12 works better on the old system cos they are made to accommodate for that gas, when the new gas is installed the latent heat of vaporisation of the gas is different which means the the heat(chilled air)taken out of the gas and put into the car as cooled air is allot less. if you were to changed the evaporator inside the car to a bigger one then u would have allot colder air.
as for being illegal well yes but no. Aircraft still use this old r12 gas for their a/c systems and large commercial aircraft use it in the cargo's as a fire extinguisher. the gas is still available but only to people with correct qualifications. the only way for an automotive dealer to obtain r12 is by evacuating an old system before converting it to the new one and storing it. r12 is ozone depleting so it should not be let out into the atmosphere.
now for replacing parts. a new receiver dryer (the round thing at the front with a sight glass) should be fitted as inside the drier is a coalescent which removes water vapor from the system. water in the system can freeze the thermal expansion valve.
to replace the gas the system should be completely evacuated to save the gas. then parts changed. if you want to remain on the old gas then only the drier needs to be changed and you need to find someone who has r12 gas and is willing to do it. if you are going to convert to r134a then the drier, thermal expansion valve, and the valves for putting the gas in need to be changed as the valves are different so as to stop putting the 2 gasses together. a new gas is now available which will mix with the r12 but is very expensive.
hope this has helped abit.
Previous Topic:Wireing diagram
Next Topic:MX83 Cressida Cruise Control
Current Time: Mon Oct 26 06:00:51 UTC 2026
Total time taken to generate the page: 0.065192937850952 seconds
