Toymods » Tech & Conversions » Strange Missing/Hesitating/Fuel Delivery Issue when cruising
RobST162
Strange Missing/Hesitating/Fuel Delivery Issue when cruising Wed, 03 August 2005 00:23 Go to next message
Got the car back from the panelbeater on Sat to discover that it has started missing when there is a moderate throttle with the revvs between 2 and 3k usually. Though sometimes earlier I get this problem.
It's like what it feels like when you run out of petrol.
At WOT the car feels great, so I would be surprised if it was the pump.
And it idles great too!
But after cruising at 60 in 4th for 30 seconds it starts to get angry 50% of the time or so. Been having a bit of trouble isoloating it and wondering if you all have any ideas Smile
I also checked to make sure the air pipes were connected well, as that can cause issues like this
Re: Strange Missing/Hesitating/Fuel Delivery Issue when cruising Wed, 03 August 2005 01:35 Go to previous messageGo to next message
it might actually be the O2 sensor Wink (for once)
sinc it takes a little time to occur (the ECU adjusting to the incorrect signal) and only happens during cruising..
check that wires have not been detached perhaps, and try to get a multimeter onto the O2's output wire to se what it is doing when you get the hesitations.. on cruise it should be flicking between high and low voltages (maybe 0.8/0.2V?) as the ECU adjusts, but if it rails either way, the ECU may be overcompensating..
Cya, STewart
zasa
Re: Strange Missing/Hesitating/Fuel Delivery Issue when cruising Wed, 03 August 2005 03:05 Go to previous messageGo to next message
the other gt4 did this also. replacing the filthy fuel filter fixed it
RobST162
Re: Strange Missing/Hesitating/Fuel Delivery Issue when cruising Wed, 03 August 2005 05:38 Go to previous message
hey thanks guys
I ran a diag on ECU and it says that my OS sensor has run an error code..
Stewart, you don't still have any of these do you? Wink
edit:zasa thanks man my fuel filter is hardly a year old, and since it's happy at WOT and idle I wonder if maybe it's something else??
[Updated on: Wed, 03 August 2005 05:47]
Previous Topic:Found the culpirite!
Next Topic:2s W55 onto 3SGE
Current Time: Sun Oct 18 20:00:57 UTC 2026
Total time taken to generate the page: 0.008267879486084 seconds
