Toymods » Tech & Conversions » COOLING SYTEMS/ putting thermos on switch
AE82bigport
S.A
August 2005
icon1.gif  COOLING SYTEMS/ putting thermos on switch Wed, 03 August 2005 04:37 Go to next message
HEY
If any one nows how to wire thermos to a swith could they please tell me how. been trying to do it on a stockish AE82 SECA Twimcam and made more of a mess, also witch one is it best to do it to the engine side or grill side.
Re: COOLING SYTEMS/ putting thermos on switch Wed, 03 August 2005 04:42 Go to previous messageGo to next message
please search, this topic has been covered many many times by myself and many others.
Re: COOLING SYTEMS/ putting thermos on switch Wed, 03 August 2005 04:59 Go to previous messageGo to next message
I'm feeling generous.
http://forums.toymods.org.au/index.php?t=msg&t h=67720
AE82bigport
S.A
August 2005
Re: COOLING SYTEMS/ putting thermos on switch Wed, 03 August 2005 05:38 Go to previous messageGo to next message
thanks for that link at least someone could help,
but dose that show you how to wire it onto a manual on/off switch in side the car?
[Updated on: Wed, 03 August 2005 05:47]
Re: COOLING SYTEMS/ putting thermos on switch Thu, 04 August 2005 02:41 Go to previous messageGo to next message
If you are using a thermoswitch, you DO NOT want to have a manual override switch for any reason other than wank factor.
Can i ask WHY you want a manual switch?
The thermoswitch (automatically switches at a set temperature) is located in your thermostat hosuing on top of the gearbox in an AE82. All the stock wiring should be there and function perfectly without your interference. If the thermoswitch is buggerised, go down to pick n payless or your local self serve wreckers and pinch a couple from just about ANY FWD toyota and it will work just fiiiiiiiine.
You will need a 17mm spanner - that is all.
AE82bigport
S.A
August 2005
Re: COOLING SYTEMS/ putting thermos on switch Thu, 04 August 2005 03:43 Go to previous messageGo to next message
i had my subaru 4wd thermos on a switch and when i hit the beach it was good to have the thermos on befor it started to heat up, now with the rolla when i hit the hills i wanted the same thing, plus since ive had the car they have never come but i might have to go vist u pull it for a new thermoswitch.
Re: COOLING SYTEMS/ putting thermos on switch Thu, 04 August 2005 07:36 Go to previous messageGo to next message
remember - a thermofan or any fan for that matter is COMPLETELY USELESS at any speed above 25-30kph. In fact rolling along at 40kph will be far better cooling Smile
HyDrA
Adelaide, SA
Re: COOLING SYTEMS/ putting thermos on switch Thu, 04 August 2005 09:01 Go to previous message
Just dont drive around in the city Razz Keep it to the hills, where you should be going very fast providing lots of airflow.
Previous Topic:AE86 Fuel System Upgrade
Next Topic:Extractors on 18RG from RA28 into RA23
Current Time: Sun Oct 18 19:37:28 UTC 2026
Total time taken to generate the page: 0.13938903808594 seconds
