Toymods » Tech & Conversions » 2JZ-DIFF
The Count
2JZ-DIFF Wed, 03 August 2005 06:25 Go to next message
i wanted t buy the diff off a 2JZ-GTE
just a few questions on it
i know its an LSD
but wat are the code names for it
and will it bolt up to my 1JZ diff
Re: 2JZ-DIFF Wed, 03 August 2005 06:52 Go to previous messageGo to next message
That doesn't even make sense. A 2JZ is an engine, it doesn't have a diff. Confused
If you're referring to the JZA80 Supra, the answer is "maybe". Early TT's came with a B series diff which will not fit in your Soarer. Late TT's came with an A series diff, and that will fit in your Soarer. I can't remember the changeover date, but your best bet is to ask the seller if it's an A or B diff.
dojobi
Re: 2JZ-DIFF Wed, 03 August 2005 07:14 Go to previous messageGo to next message
Does anyone know if one these Supra diffs will fit a JZX100 Chaser? I'm pretty sure mine didn't come with one (haven't checked yet though).
I know they're not too common, but I thought someone might know.
Re: 2JZ-DIFF Wed, 03 August 2005 08:37 Go to previous messageGo to next message
See above - it depends if the diff in question is an A or B series, and whether your Chaser has an A or B series diff from the factory. I'm 90% sure you'd have an A diff, as did most larger RWD Toyota's from the early 90's (apart from the TT Supra).
E30-323ti
Re: 2JZ-DIFF Wed, 03 August 2005 09:38 Go to previous messageGo to next message
I have heard the B series does bolt-in in place of a A series, you also need the Axles 'cause the B series is wider than the A.
dojobi
Re: 2JZ-DIFF Wed, 03 August 2005 13:36 Go to previous messageGo to next message
Thanks guys. If I'm lucky I'll actually have a diff from the factory anyway, but the car is still at the compliance workshop, so I haven't had a good look at it yet.
EDIT: Err, LSD I mean. It better have a diff from the factory or I'm not going anywhere Smile
[Updated on: Wed, 03 August 2005 13:37]
terra
July 2005
Re: 2JZ-DIFF Wed, 03 August 2005 20:45 Go to previous messageGo to next message
im pretty sure the A will bolt up but youll need the mounting bushings from teh supra, and youll also need to trim it down a bit but the thing is the tailshaft is diffrent, no?
Re: 2JZ-DIFF Wed, 03 August 2005 23:12 Go to previous messageGo to next message
E30-323ti wrote on Wed, 03 August 2005 19:38
If you buy the complete housing then yes you can put a B diff in a Supra that came with an A diff. Not sure it this applies to the Soarer/Chaser etc since they probably came with different length axles.
stradlater
Arthurs Creek, Victoria
Re: 2JZ-DIFF Thu, 04 August 2005 07:40 Go to previous messageGo to next message
dojobi wrote on Wed, 03 August 2005 17:14
Your JZX100 didn't come with a Diff??
That's almost as bad as trying to buy the diff off a 2JZ-GTE....
dojobi
Re: 2JZ-DIFF Thu, 04 August 2005 07:42 Go to previous message
hehe, yeah I noticed that as soon as I posted it. That's why there's an edit 1 minute later Smile
Previous Topic:Wheel Bearings - Failures/upgrades?
Next Topic:1989 cresta info needed
Current Time: Thu Oct 15 10:42:27 UTC 2026
Total time taken to generate the page: 0.0060691833496094 seconds
