Toymods » Tech & Conversions » Wolf 3D Base Map
4agte
Toronto, Downtown
Wolf 3D Base Map Wed, 03 August 2005 09:08 Go to next message
Does anyone have a wolf 3d V4 base map for preferrably an aw11 4agze if not any 4age base map will be helpfull??
[Updated on: Wed, 03 August 2005 09:09]
JustenGT4
Re: Wolf 3D Base Map Thu, 04 August 2005 02:44 Go to previous messageGo to next message
you can download a heap of maps off their website
4agte
Toronto, Downtown
Re: Wolf 3D Base Map Thu, 04 August 2005 02:56 Go to previous messageGo to next message
they didnt have one last time i looked and when my tuner spoke with steve from aems they only had a base map for a 3sgte which has some of the same values for the ignition that my tuner was after
edit: thanks for the help nonetheless
[Updated on: Thu, 04 August 2005 02:56]
Re: Wolf 3D Base Map Thu, 04 August 2005 03:06 Go to previous messageGo to next message
take the 3SGTE map, scale it for displacement and injector size and call it good... the wolf uses ms measurements for injectors no? should be easy, and your tuner should have half an idea as to base map Wink after all, it's a mathematical calculation to work out the maximum fuel for each load point.. timing is more fun tho..
JustenGT4
Re: Wolf 3D Base Map Thu, 04 August 2005 03:19 Go to previous messageGo to next message
Have a look at the capacity to injector size ratio for the 3S and compare to what you are running...that map should get you 90% there.
I ran a 3TGT map to get my 3SGTE going initially. Even that dodgy tune was good enough for 240rwkw...there's no magic, most engines run a very similar tune...enough to get you up and running anyway
Chris Davey
sunny coast, qld
Re: Wolf 3D Base Map Thu, 04 August 2005 05:02 Go to previous messageGo to next message
oldcorollas wrote on Thu, 04 August 2005 13:06
What is this mathematical formula you speak of? Wink
Re: Wolf 3D Base Map Thu, 04 August 2005 05:27 Go to previous messageGo to next message
i believe it's called Megatune Razz
put in the AFR, the engine size, the injector size and it tells you what 100% VE will require in ms..
then you can just scale it up and down for the boost section of the tuning.. and for the vac section, just scale it down a bit Wink (since each point of engine operation can be neatly describeed by the Volumetric Efficiency...ie the amount of air, which directly correlates to the amount of fuel)
cars will run with a remarkable range of AFR..
carbies worked too didn't they Razz
[Updated on: Thu, 04 August 2005 05:29]
Chris Davey
sunny coast, qld
Re: Wolf 3D Base Map Thu, 04 August 2005 06:43 Go to previous messageGo to next message
Hmm, interesting. I see what you are saying about the VE changing but how do you accurately know what it is at a given point? Eg 5psi? Also, not sure if it will help on tuning a wolf as the x axis is from 0 to 107 and AFAIK these numbers are based on load not manifold pressure. So not sure how you would use the data in wolf software
Re: Wolf 3D Base Map Thu, 04 August 2005 06:51 Go to previous messageGo to next message
well...
at 5psi = 1+ (5/14.7) = 1.34 so the MAXIMUM VE you will get is 134%
the boost part is easy because you have (1atm+boost)x100%VE as the max amount of fuel you need, and it should be reasonably linear.. of course this will have it running rich, but better safe than sorry.
ahh load points Wink
so it depends on what MAP sensor you are using? the max of the MAP sensor is 107 on the load scale? if so you just scale it/convert so you are working with real numbers Wink
the relationship between load and manifold pressure must be linear.
load is a stoopid measurement to work with.. much easier to work with absolute pressures.. in that case, 0 load could be sayy.. 30-40kpa, and full load could be.. 200kpa (1 bar boost)
just takes a little while to convert it all back to sensible units, work out a rough mapo, then convert back to silly Wolf units Razz
4agte
Toronto, Downtown
Re: Wolf 3D Base Map Thu, 04 August 2005 07:08 Go to previous messageGo to next message
thanks for the replies the tuner is having problems with the wolf only firing the 4th injector and a problem with the spark. The distributer in the 4agze aparantly has 24 teeth and with the wolfs aparantly you have to tell it to divide the 24 teeth by 6. He tried doing that and it only started working as above. He aparantly tried a 4 tooth distributer and it started injecting and firing on all 4 cylinders so he reccomends removing 20 teeth in the distributer to leave 4 (its a bit over my head). I should have just had it converted to cas as some tuners said is better
Re: Wolf 3D Base Map Thu, 04 August 2005 07:16 Go to previous messageGo to next message
4agte wrote on Thu, 04 August 2005 17:08
yup...
it might be better to remove 19 teeth, and have 4 teeth plus a TDC cyl 1 reference tooth (as shown in the Wolf manual), and then it is effectively a CAS anyway...
if you are firing with waste spark, you may want 4+2 teeth, so it knows when cyl's 4 and 2 are up.
wolf seems ot be a bitch to set up, and i found the manuals fairly non-specific at critical moments Wink call Wolf and ask tho, they seem to be helpful.
G'luck
Chris Davey
sunny coast, qld
Re: Wolf 3D Base Map Thu, 04 August 2005 07:20 Go to previous messageGo to next message
I would say it would be as long as you don't have an auto! That is the problem I am having.
Thanks oldcorollas. I will have another read of that when I get home to absorbe it Razz I am just trying to see how the theory matches up to real life as I can tune with my wideband Smile
Re: Wolf 3D Base Map Thu, 04 August 2005 07:27 Go to previous messageGo to next message
Chris Davey wrote on Thu, 04 August 2005 17:20
you lucky lucky lucky lucky lucky lucky bastard!! Laughing
4agte
Toronto, Downtown
Re: Wolf 3D Base Map Thu, 04 August 2005 07:53 Go to previous messageGo to next message
oldcorollas wrote on Thu, 04 August 2005 17:16
yup...
G'luck
cheers stewart id like to have waste spark but im told i need dual coil so that rules that out maybee some day when i have to pass an emissions test Very Happy
The tuner im working with has said to me that all the wolfs hes tuned are difficult to set up but quite good computers once thats done. Maybee its because he used to tuning autronics... What he says also agrees with your comments about the manuals that they are confusing and dont go into any real detail with some things.
We have been speaking to wolf but they seem to be only semi helpfull acording to my tuner but i havent had any issues with contacting them
Chris Davey
sunny coast, qld
Re: Wolf 3D Base Map Thu, 04 August 2005 08:25 Go to previous messageGo to next message
oldcorollas wrote on Thu, 04 August 2005 17:27
www.wbo2.com $500ish delivered with everything. (maybe a bit more to japan Razz) I recommend them to anyone with an aftermarket ECU.
BTW the wolf map sensor is a 2.5 bar unit. I will see what load point it goes to next time at what boost level.
[Updated on: Thu, 04 August 2005 08:32]
Re: Wolf 3D Base Map Fri, 05 August 2005 09:39 Go to previous messageGo to next message
Yes... the Wolf sure can be a plick to get working initially, although isn't too bad once you nut it out. The manuals are, well, severely lacking, ringing Steve is an issue, simply because he is constantly SO busy answering peoples problems all day long, and on it goes.
And Chris, my wideband's fancier than yours Razz HAH! (kidding)
Chris Davey
sunny coast, qld
Re: Wolf 3D Base Map Sat, 06 August 2005 00:36 Go to previous message
mrshin wrote on Fri, 05 August 2005 19:39
Laughing Which one do you have?
Previous Topic:2t-b wont idle
Next Topic:3sge burning LOTS of oil!
Current Time: Sat Oct 10 00:05:26 UTC 2026
Total time taken to generate the page: 0.0059239864349365 seconds
