Toymods » Tech & Conversions » ABS switch
wagonist
Toymods Club Treasurer
ABS switch Tue, 17 December 2002 01:37 Go to next message
I want to put a switch on my dash to turn the ABS off, mainly because the stopping on dirt leaves something to be desired.
Does anyone know what wire I should put the switch onto?
PayneyCelica18rg
Southport
Re: ABS switch Tue, 17 December 2002 05:44 Go to previous messageGo to next message
find the fuse, take it out, and then just put a switch there(i would put an inline fuse back in too though)well not in the fuse box wither, but run the wires from the posts.
haggis
Re: ABS switch Tue, 17 December 2002 06:08 Go to previous messageGo to next message
Also, keep in mind if you turn thr ABS off, it may log an error code in the ECU, if the ABS if tied into that system. Alternativly, the ABS controler may log its own error code.
This shouldnt cause any problem with the way the system works when its turned back on.
Craig.
wagonist
Re: ABS switch Tue, 17 December 2002 21:36 Go to previous message
I hadn't thought about the error code problem, I don't have an ECU so it shouldn't matter. But then I realised that my speedo works off the ABS sensors (I think, there's no speedo sensor on the gearbox, just a blanking plate where it normally plugs in) so that could cause a problem.
Is it possible to just cut the power to the servos while not disturbing the rest of the system?
Previous Topic:Whats different between a twin cam AE82 and the CS, CSX ??
Next Topic:Sleepy headlight conversion for ra65?
Current Time: Sat Nov 21 00:25:02 UTC 2026
Total time taken to generate the page: 0.01999306678772 seconds
