Toymods » Tech & Conversions » what mods to achieve 75kws
atoyot
melbourne
August 2005
what mods to achieve 75kws Thu, 04 August 2005 09:33 Go to next message
hi
if this has bn asked b4, can u pls pnt me to that thread....but here is my question,,,,what mods do i need to achieve not more than 75kws - 80 kws on a EP91 4EFE CAR.....thanks
Re: what mods to achieve 75kws Thu, 04 August 2005 09:36 Go to previous messageGo to next message
Bolt a turbo on.
Or just drop in a 4EFTE
atoyot
melbourne
August 2005
Re: what mods to achieve 75kws Thu, 04 August 2005 09:49 Go to previous messageGo to next message
yeah but, i need to know whats the minimum setup.....
4agte
Toronto, Downtown
Re: what mods to achieve 75kws Thu, 04 August 2005 09:57 Go to previous messageGo to next message
whichever one is the smallest Razz
edit: starting with a motor thats allready designed for boost usually works out cheaper in the long run especially if you want to make more power later down the track i would expect it would cost you somewhere between 5-10k depending on how much of the work you do yourself
[Updated on: Thu, 04 August 2005 09:59]
atoyot
melbourne
August 2005
Re: what mods to achieve 75kws Thu, 04 August 2005 10:08 Go to previous messageGo to next message
can i start with just the turbo, piping, fuel reg, bov, custom manifold????
Jezza
Re: what mods to achieve 75kws Thu, 04 August 2005 10:14 Go to previous messageGo to next message
go to www.austarletclub.com and search around of those forums
there r lots of turbo starlets on there, and converted EP91's
the 4e-fte makes 100kw at the flywheel stock, add an exhaust and filter and u should make that 75-80 at the wheels quite easily
4agte
Toronto, Downtown
Re: what mods to achieve 75kws Thu, 04 August 2005 10:16 Go to previous messageGo to next message
dont forget your aftermarket ecu dont kid yourself doing it properly will cost about 5k maybe more buy a half cut if at all possible so you will get gearbox driveshafts computer etc etc it will work out cheaper in the end
Jezza
Re: what mods to achieve 75kws Thu, 04 August 2005 10:56 Go to previous messageGo to next message
the std ecu is good upto about 175hp atw i believe, certainly over 150hp atw, which is much more than the asked 75kw
atoyot
melbourne
August 2005
Re: what mods to achieve 75kws Sat, 06 August 2005 03:57 Go to previous messageGo to next message
Jezza wrote on Thu, 04 August 2005 20:56
r u sure abt ths...coz all i want to achieve is from stock 55kw to 75kw...if i do this project, the most expensive item i have to buy is the customized manifold...i believed cost around $600
Jezza
Re: what mods to achieve 75kws Sat, 06 August 2005 05:55 Go to previous message
thats the stock 4e-fte ecu
go for the halfcut and chuck it all in your starlet, its definately the way to go (ie cheapest)
Previous Topic:JZA70 Digi dash on MA70 Supra
Next Topic:Disc Brake shims
Current Time: Sun Oct 18 04:35:28 UTC 2026
Total time taken to generate the page: 0.0060219764709473 seconds
