Toymods » Tech & Conversions » 18RC vs 18RG fuel pump
Mr DOHC
18RC vs 18RG fuel pump Thu, 04 August 2005 10:53 Go to next message
does anyone know if they are the same thing, or if what way they are different
TA-022
Glenmore Park, NSW
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 00:11 Go to previous messageGo to next message
i know the oil filter adapter is the same between them.
i assume alot of the accessories are fairly interchangable between
the 18r and 18rg.
but cant say for sure...also cant blame ya for making sure either. gl
TurboRG
Nor Calif USA
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 04:00 Go to previous messageGo to next message
you can use a RC pump on a stock RG(I did). But, when you start building more performance. the RC pump will run out of steam.
Mr DOHC
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 08:32 Go to previous messageGo to next message
what do u class as "more"
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 08:47 Go to previous messageGo to next message
EDIT: never mind. read it as oil pump, not fuel pump. Laughing
[Updated on: Fri, 05 August 2005 08:48]
Scootaphill
Geelong, Vic
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 12:52 Go to previous messageGo to next message
If the Green bible is anything to go by... which it is... the fuel pumps are the same.
every time there is a difference between the 18r and the rg it shows it ie the oil pump for both motors is shown in an exploded view
how far beyond standard the original pumps are good for who knows? you would have to work out the flow from a std pump and what your needs for the worked motor and go from there i suppose
hope that helps
phill
TurboRG
Nor Calif USA
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 18:51 Go to previous messageGo to next message
Mr DOHC wrote on Fri, 05 August 2005 18:32
once you have more compression/bigger bore and
bigger carbs/port the head and run higher rpms.
the stander fuel pump can't keep up.
Mr DOHC
Re: 18RC vs 18RG fuel pump Fri, 05 August 2005 22:53 Go to previous messageGo to next message
look at my specs, u reckon it'll keep up
makevelli
July 2005
Re: 18RC vs 18RG fuel pump Sat, 06 August 2005 09:53 Go to previous messageGo to next message
whats the diff between an 18RG and 18RC?
im sorry i couldn't find any info on the 18RC
earlyrolla
Re: 18RC vs 18RG fuel pump Sat, 06 August 2005 11:05 Go to previous messageGo to next message
Mr DOHC, Do you want to run the risk of it not keeping up and potentially leaning out your engine?
Unless someone here can give flow measurements vs. RPM or is willing the measure the flow vs. RPM (by supplying the fuel to the engine with an electric pump and measuring the flow of the mechanical pump) then I would be careful about here say.
If you had the time then fit a fuel pressure gauge to mechanical pump and watch to see sufficient fuel pressure is being maintained at continuous high RPM e.g. when you have it dynoed. If fuel pressure drops back to 0 then you are going to have problems...
In my opinion I would use an aftermarket fuel pump like a Holley Red (no external reg required) with a fuel pressure gauge fitted on a pretty hot engine like yours.
http://www.holley.com/products.asp?product=12-801- 1
[Updated on: Sat, 06 August 2005 11:30]
Re: 18RC vs 18RG fuel pump Sat, 06 August 2005 14:14 Go to previous messageGo to next message
Definitely use an electric pump for a warmed-over 18R-G. The stock pump is adequate for a stock setup but that's about it.
Mr DOHC
Re: 18RC vs 18RG fuel pump Sat, 06 August 2005 23:08 Go to previous messageGo to next message
i'm not that cheap, i just need something to keep my engine goig for the next few days, i wasnt able to find out what the difference was
i have just jammed my old one on there for the time being, might get a holley blue
Mr DOHC
Re: 18RC vs 18RG fuel pump Sun, 07 August 2005 01:13 Go to previous message
the standard pump was easily able to hold up to the dyno runs of 107rwhp, while still running rich
Previous Topic:Where did this bit of metal come from?
Next Topic:3sgte into a sprinter ae86
Current Time: Sat Nov 21 05:18:40 UTC 2026
Total time taken to generate the page: 0.0048539638519287 seconds
