Toymods » Tech & Conversions » 1JZ to W5x gearbox? can it be done?
AE86_Sprinter
Perth, WA
1JZ to W5x gearbox? can it be done? Tue, 04 June 2002 04:48 Go to next message
I seen the conversion that they did on the ZOOM 240Z, but all that stuffing around woul dhave to cost more than the appropraite gearbox, especially after you factor in the purchase of the W5x gearbox.
The donor car has a W5? (2wd hilux) already, be good if it could be adapted to that. Better if i could get a R154(?) tho...
Mike
Re: 1JZ to W5x gearbox? can it be done? Tue, 04 June 2002 05:09 Go to previous messageGo to next message
Ultimately a R154 would be the best bet. You can use the bellhousing from a 2JZGE which used a W58. Or I'm sure you could get one from Dellow or someone else like that.
AE86_Sprinter
Perth, WA
Re: 1JZ to W5x gearbox? can it be done? Tue, 04 June 2002 05:28 Go to previous messageGo to next message
IC,
that might be the best option as a r154 is like rocking horse shit.....but then I would need flywheel/clutch etc etc...
whats a decent price for a bare motor these days?
the thoughts of a 350hp mini truck is quite inviting Smile
Mike
kalium
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 06:22 Go to previous messageGo to next message
This is the exact dillema I am in now.
I have a 1JZ but no flywheel,clutch or gearbox
I can get a 1GGTE W58 for $600, or an R154 for $1100 bucks.
Im thinking that at that price, the R154 is the best bet.
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 06:25 Go to previous messageGo to next message
What are you planning to put it in? There is the problem witht he R154 being huge...
kalium
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 07:45 Go to previous messageGo to next message
Putting it into a 260Z
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 07:54 Go to previous messageGo to next message
Yes it can.
You need to get all the manual stuff from a 2JZGE (flywheel, slave, fork, thrust bearing carrier, clutch kit, W5x box and bellhousing to suit JZ-W5x box). Sounds easy but less than 5% of all 2JZGEs were in manual form. Good luck!
Alternatively a whole kit (excluding gearbox)can be purchased from Dellow or Castlemaine Rod Shop for around the 1K mark. Or you could custom fabricate something from the auto bellhousing and the bellhousing on your W5x (ie a cut and shut job).
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 09:30 Go to previous messageGo to next message
$1000 for the lot?
what sort of a clutch/flywheel do you get in with that deal?
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 09:44 Go to previous messageGo to next message
Dellow will provide you with a fat ass 14 kg flywheel, a Holden 1 tonner pressure plate and custom 9.5" clutch plate. Jeff Dellow said he wouldn't be prepared to lighten the flywheel to less than 12 kg. That is effing heavy. Don't know about the CRS kit. The std Toyota 2JZGE flywheel weighs 8-9 kg (bathroom scales) and utilises a 240 mm clutch (same as the 7MGE). The chromemoly one I had made weighs 6kg.
The price figure is ballpark - I roughly added the prices on the pricelist I had (and now can't find). I suggest you ring the respective companies. Dellow will send you a pricelist but their customer service leaves a little to be desired according to some (but my experience with them has been OK). Not sure about the CRS one entirely but RH suggested around "$1000".
[Updated on: Wed, 25 September 2002 09:48]
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 09:48 Go to previous messageGo to next message
well
that uses up the entire "$1000" that I'd allowed for extras in my conversion Razz I'm hoping that includes a bellhousing.
could it really cost much more than that to simply get the tranny tunnel widened for a r154?
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 10:09 Go to previous messageGo to next message
and for that extra $1000, you could purchase yourself a 2jz front cut.
although I suppose if you were going to use that kit, you could grab an auto 1jz front cut
wilbo666
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 11:23 Go to previous messageGo to next message
So if you have a normal W5x behind say a 7M, 5M ect what would you have to do to bolt a 1J to it?
JAZE
cronulla
Re: 1JZ to W5x gearbox? can it be done? Wed, 25 September 2002 11:51 Go to previous messageGo to next message
i bolted my 1JZ to a W58 on sat and it fitted like a dream
i biought the gearbox/flywheel/clutch/bellhousing/starter off a 2JZ GE motor at jap auto performance it was 500 bucks for the lot and it just so happened to have a 550 pound pressure plate in it so 1 clutch plate later it all works,
why dont you just do that, and that price is steep for that box i can get you a W58 of a 1GGTE for 350 or if i see a JZGE around with a manual ill let you know
Re: 1JZ to W5x gearbox? can it be done? Thu, 26 September 2002 09:12 Go to previous messageGo to next message
Yeah I got a 2JZ-GE box as well (sounds like I got ripped though, $850 just for the box). This is definitely the one to have, as it has a bigger input shaft bearing compared to the earlier W58's as found behind 5M's and 7M's. Apparently this addresses one of their major weaknesses (ie snapped input shafts).
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 1JZ to W5x gearbox? can it be done? Thu, 26 September 2002 10:45 Go to previous messageGo to next message
Hey JAZE, I'm looking for a supra 5 spd at the moment, I'd be very interested in getting a W58 for a price like that.
Where do I line up?
JAZE
cronulla
icon14.gif  Re: 1JZ to W5x gearbox? can it be done? Thu, 26 September 2002 12:23 Go to previous message
email me and ill line it up for you
Previous Topic:1JZ Digi Dash info Needed...
Next Topic:cressy swaybar upgrade
Current Time: Sat Oct 31 14:43:27 UTC 2026
Total time taken to generate the page: 0.080843925476074 seconds
