Toymods » Tech & Conversions » GOOD mechanic in Melb for AW11sc
Karl
GOOD mechanic in Melb for AW11sc Tue, 17 December 2002 08:38 Go to next message
Are there many around?
Do they even exist? Very Happy Very Happy
._T_.
Re: GOOD mechanic in Melb for AW11sc Tue, 17 December 2002 21:42 Go to previous messageGo to next message
depends on what you want done to it.
T
Corvid
Re: GOOD mechanic in Melb for AW11sc Tue, 17 December 2002 23:52 Go to previous messageGo to next message
Just do it yourself Smile.. i wont take my aw11 GZE to any mechanic Smile..
Karl
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 01:14 Go to previous messageGo to next message
Well... I'll be getting myself an AW11 soon, and was hoping to find someone reliable to tune it up a bit and maybe do some mods later on when I've saved up some more $$$... stuff like relocating the intercooler to the front, etc...
I also just want to know where to go just incase I screwed up something myself...
._T_.
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 01:51 Go to previous messageGo to next message
relocating the intercooler to the front? think you will need a really crap mechanic to do that mod for you!!
T
Corvid
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 01:52 Go to previous messageGo to next message
GOOD LORD!
Karl
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 02:17 Go to previous messageGo to next message
Embarassed Embarassed
what's wrong with a front mount intercooler for an AW11?
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 03:41 Go to previous messageGo to next message
The fact you'd have roughly 5m of inlet tract is the first thing that comes to my mind...
Karl
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 10:28 Go to previous messageGo to next message
ok, so maybe that's a bad idea....
(i still dont understand how an intercooler sitting on top of an engine can be a good thing... hot air rises, no?)
But it's still useful to know a good mech just in case things get out of hand... say, if i kill my gearbox or something...
._T_.
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 21:54 Go to previous messageGo to next message
throttle response would be interesting to say the least...
intercoolers sititng on engines don't work as wel las they could (interwarmer?) but where else do you plan to mount it? best alternative would be to setup a water/air setup, but loads of work for little gain. otherwise you could retrofit a sw20 gt type i suppose?
so you think you'll kill a e51 s/c gearbox do you? they are pretty strong you know!!
T
Karl
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 22:47 Go to previous messageGo to next message
I donno... things seem to break in my hands... but the gearbox was just an example...
Smile
I just wanted to know a good guy to go to for tuning, servicing, and to fix stuff when I break it...
Corvid
Re: GOOD mechanic in Melb for AW11sc Wed, 18 December 2002 23:21 Go to previous messageGo to next message
Looks like im buying that box off that guy Toby,
How strong are the e51's?
._T_.
Re: GOOD mechanic in Melb for AW11sc Thu, 19 December 2002 01:42 Go to previous messageGo to next message
corvid,
good to hear. strange you couldn't find a cheap on in nsw though!! (then again ~$400 is still cheap - try pricing up a new one!!)
the e series box is used in the gt4 and the sw20 got as well - there are numerous examples of these cars running 400+ hp through them, and with some care they run fine (don't expect them to live if you do drop-backs!). the e series also runs an internal oil pump - you can easily hook it up to a trans cooler to help it cope with high hp. synthetic oil is a good idea too
T
Corvid
Re: GOOD mechanic in Melb for AW11sc Thu, 19 December 2002 02:57 Go to previous messageGo to next message
Sweet... oh well i guess it was worth the extra effort to put that big puppy in Smile
Ummmmmmm... as for the trans cooler idea.. Smile
There is a bent pipe on the outter of the box housing.. ive allways figured that thats what it was.. so if i unbolted then and through the cooler inline with it id be magic wouldnt i?
Also due to it having the lsd centre what oil should i use? id like to run synthetic.. But what brand/visc. should i be looking for?
Thanks again for your help.
._T_.
Re: GOOD mechanic in Melb for AW11sc Thu, 19 December 2002 21:52 Go to previous message
corvid,
hopefully!!
yes that "U" tube is the pressure line from the pump (or is it the return? will have to look in the workshop manual now...)
so you just unbolt it and set up the cooler lines there.
we have used castrol syntrans. there is also a castrol syntrax, which was designed for all wheel drive transmissions. syntrax is cheaper. is not cheap (syntrans is about $24-27 /L), but it does seem to work quite well!
T
Previous Topic:Stud Pattern
Next Topic:KE15 suspention/handbrake/brakes
Current Time: Fri Nov 20 20:56:26 UTC 2026
Total time taken to generate the page: 0.0053858757019043 seconds
