Toymods » Tech & Conversions » wjich way does clutch go in
Mr DOHC
wjich way does clutch go in Sat, 06 August 2005 02:57 Go to next message
which way faces the flywheel
http://img293.imageshack.us/img293/9052/img79507mn.jpg
http://img293.imageshack.us/img293/1658/img79516pe.jpg
cant do anything else till i know this
Rallystanza
Re: wjich way does clutch go in Sat, 06 August 2005 03:20 Go to previous messageGo to next message
First picture side faces the flywheel.
Do it,
Jeremy
Re: wjich way does clutch go in Sat, 06 August 2005 04:25 Go to previous messageGo to next message
what he said
ra40coupe
May 2005
Re: wjich way does clutch go in Sat, 06 August 2005 04:41 Go to previous messageGo to next message
should be marked, FLYWHEEL THIS SIDE.
otherwise the big chucky part inside the pressure plate
Mr DOHC
Re: wjich way does clutch go in Sat, 06 August 2005 05:18 Go to previous messageGo to next message
ra40coupe wrote on Sat, 06 August 2005 14:41
nay
thanx everyone
Re: wjich way does clutch go in Sat, 06 August 2005 14:05 Go to previous messageGo to next message
I got it backwards when I first put my 2JZ together. The results weren't pretty. Embarassed
Mr DOHC
Re: wjich way does clutch go in Sat, 06 August 2005 23:02 Go to previous messageGo to next message
i remember that, what happened again
Re: wjich way does clutch go in Mon, 08 August 2005 00:25 Go to previous messageGo to next message
Let's just say the flywheel bolts got "lightened". Shocked
Skip
Re: wjich way does clutch go in Mon, 08 August 2005 00:27 Go to previous messageGo to next message
I also got my 1JZ one backwards.
The results were devistating to my engine.
Merudo
Central Coast, NSW
February 2005
Re: wjich way does clutch go in Mon, 08 August 2005 00:37 Go to previous messageGo to next message
Shocked
what did it do to the engine?
wilbo666
Re: wjich way does clutch go in Mon, 08 August 2005 00:56 Go to previous messageGo to next message
Merudo wrote on Mon, 08 August 2005 10:37
Shocked
Screwed the crank thrust washers if I recall...
Skip
Re: wjich way does clutch go in Mon, 08 August 2005 01:41 Go to previous messageGo to next message
Munted front thrust washer, front thrust washer fell out, rear thrust washer fell out, carnk munted foward thrust faces. Cheaper to buy another wrecker engine than repair Laughing
Merudo
Central Coast, NSW
February 2005
HOLY CRAP!
Damn, well you certainly want to be 1000 percent sure you got it in the right way then, huh...
ndgcpr
Pine Rivers QLD
April 2005
Re: wjich way does clutch go in Mon, 08 August 2005 23:17 Go to previous messageGo to next message
2 things, if the clutch is in backwards do you know about it straight away? or does it take time to destroy the motor?
Also is that what a clutch should look like? It looks a bit chopped up. when i had mine out it was fairly clean.
Re: wjich way does clutch go in Mon, 08 August 2005 23:42 Go to previous messageGo to next message
In my case it was immediately obvious I had the clutch in backwards because you could hear the clutch plate grinding against the flywheel bolts. Not a nice sound at all.
Skip
Re: wjich way does clutch go in Tue, 09 August 2005 01:52 Go to previous messageGo to next message
In my case I started the car in neutral, after about 1 minute I clutched in to engage reverse and take off, at this point it made a nasty whining noise (crank grinding thrust washer real bad). I clutched out and put it in neutral again after about 30 seconds the engine stalled and would not sturn over again it had bound up. When I undid my bellhousing bolts the pressure was releaved and the motor turned again but it was short of thrust washers which were now lyng in the sump (didnt know this at the time, took another couple hundred km's of driving and an oil change to find out).
But anyway I should have known there was a problem as I had a fair bit of problems getting the engine and bellhousing to mate up properly.
styler
Re: wjich way does clutch go in Tue, 09 August 2005 07:15 Go to previous message
now i know why my old corona made a noise Laughing
Previous Topic:4agze knock sensor help
Next Topic:cutting/crafting/drilling thin metal
Current Time: Sat Oct 24 05:40:11 UTC 2026
Total time taken to generate the page: 0.007066011428833 seconds
