Toymods » Tech & Conversions » turbo rebuild
cri_ag
northern beaches
turbo rebuild Tue, 17 December 2002 09:07 Go to next message
how hard is it to rebuild a turbo? i scored a t25 for nothing off a mate, but its a little noisy that was his excuse for putting a t28 ball bearing on. anyway is it a do it yourself job? or not realy?
TE72_Turbo
Re: turbo rebuild Tue, 17 December 2002 11:59 Go to previous messageGo to next message
Its not a problem to fit replacement bearings & seals yourself if you have a bit of mechanical know how, but you will still have to pay a turbo rebuilder to balance the whole rotating assembly before you can use it... This usually costs between $80 & $130 depending where you go, on top of the cost of the rebuild kit.
All this is assuming that both wheels, housings, wastegate flap are in working order, and that the bush style bearings have not siezed in the core.
Phil
cri_ag
northern beaches
Re: turbo rebuild Wed, 18 December 2002 10:18 Go to previous messageGo to next message
excelent thanks for that. might just have a go seeing i got the thing for nothing! any clue on where to start looking for the rebuild kit? also how do you go about taking the boost bellow the factory stock level?
Re: turbo rebuild Wed, 18 December 2002 13:41 Go to previous message
If you want less than wastegate boost you can either:
Restrict everything to hell (e.g. intake, exhaust)
See if you can change the wastegate spring
Previous Topic:RT104 Brake upgrade
Next Topic:gze piston rings
Current Time: Fri Nov 20 21:58:36 UTC 2026
Total time taken to generate the page: 0.0036489963531494 seconds
