Toymods » Tech & Conversions » 5M-GEy injectors
jesseT18
Castle Hill, Sydney
5M-GEy injectors Sat, 06 August 2005 08:03 Go to next message
after going over the entire ignition system and finding no reason to my engine not running, had a look at fuel system.
seems the injectors werent working, they arent getting any power from the injector plugs.
ive gone over a hell of a lot of wireing but still cant figure out why the injectors wont pulse.
they have + power but wont earth out when i crank the engine.
thanks, jesse
STR8 2.8
Re: 5M-GEy injectors Sat, 06 August 2005 08:22 Go to previous messageGo to next message
have you checked the terminal on the ecu?
could be an internal ecu isssue (ie. its rooted)
jesseT18
Castle Hill, Sydney
Re: 5M-GEy injectors Sat, 06 August 2005 08:26 Go to previous messageGo to next message
i checked the earths to the ecu and stuff but wasnt sure what else to check.
do i check the 2 injector plugs for earth?
jesseT18
Castle Hill, Sydney
http://img79.imageshack.us/img79/6404/5mgepinouts2jc.png
STR8 2.8
Re: 5M-GEy injectors Sat, 06 August 2005 08:50 Go to previous messageGo to next message
being earth switched it cant be anything else but the ecu if they are getting 12v.
check the wires for continuity
have you checked the resistor?
jesseT18
Castle Hill, Sydney
Re: 5M-GEy injectors Sat, 06 August 2005 08:53 Go to previous messageGo to next message
we checked the resistor for + power and it was alright.
sounds like it might be the ecu some how, strange though because ive had the car running on that ecu only days ago.
Re: 5M-GEy injectors Sat, 06 August 2005 14:10 Go to previous message
Make sure you have a really good, solid earth for the injectors (pins E01 and E02 on the ECU from memory), these should be thick chunky wires and they should earth on the inlet manifold near the injectors.
If it's not that, your ECU isn't pulsing the injectors for some reason... and there could be a hundred different reasons why.
Previous Topic:Toyota Engine Chart... maybe helpful..
Next Topic:smallport head onto 20v block
Current Time: Sat Nov 21 05:48:16 UTC 2026
Total time taken to generate the page: 0.020051002502441 seconds
