Toymods » Tech & Conversions » W57/58 check
GREENVK
August 2005
W57/58 check Sat, 06 August 2005 08:06 Go to next message
Hi all.
I've just bought myself what I believe to be an alloy sandwich plate w58 box for my turbo vk project.
The box was in a vk previously, and so came with shifter, bellhousing, crossmember etc etc all ready to bolt into mine.
My question as to if it is a real w58, or in fact a w57 remains.
I've read all the info regarding most 58's having the steel plate, but found some details of 58's also having alloy plates.
I'm guessing the best way for me to check is to count the teeth on the 5th gear and see what the ratio is. Since the box is still together, what's the procedure for counting revolutions of the output shaft while fifth gear is engaged. How many output turns should I expect to see for one input turn etc.
Thanks in advance
Re: W57/58 check Sat, 06 August 2005 08:15 Go to previous messageGo to next message
With it in 5th, one turn of the input shaft will give you 1.27 turns of the output.
wilbo666
Re: W57/58 check Sat, 06 August 2005 10:43 Go to previous messageGo to next message
GREENVK wrote on Sat, 06 August 2005 18:06
I feel that this is incorrect. I would say that MOST W58's are alloy plate (even MA70's came with alloy plate W58's, I have one, and have counted revolutions to confirm).
Cool1 is telling much truth (w58 5th gear is 0.783, 1/0.783 -> ~1.27).
Re: W57/58 check Sat, 06 August 2005 14:13 Go to previous messageGo to next message
From what I can gather most W58's are steel plate from the mid to late 80's on, but it seems kind of random as well.
As Shane said, check the ratio on 5th as that's the only real difference between the two.
GREENVK
August 2005
Re: W57/58 check Mon, 08 August 2005 09:51 Go to previous message
Thanks guys.
Checked the turns in 5th gear and it looks like it was as suspected. a w58. Happy now that I know.
Cheers!!
Previous Topic:a 3sge turbo conversion - in the flesh
Next Topic:how can i put rx7 FC Caliper into an ae86
Current Time: Sun Oct 25 19:45:13 UTC 2026
Total time taken to generate the page: 0.0038609504699707 seconds
