Toymods » Tech & Conversions » ECU and Cruise Control Q RE JZA70
ReQuieM
ECU and Cruise Control Q RE JZA70 Sat, 06 August 2005 08:24 Go to next message
Hi, well recently i found out my car came from factory with an auto and was changed over at some point, anyway I've just been out replacing my horn button (old was a annoying) and i worked out the 'cruise control' buttons on the horn (three littlies in one big horn button) were actualy connected. going by what i can find out about my model cruise should of been standard. so what i guess i'm asking is how/where am i checkin for the factory cruise control? I'm assuming some where along the throtal line, but any where else? is there a controller box hidden somewhere? What should i be looking for? sorry if its a daft Q but i've never worked with/on cruise control! Rolling Eyes
Also in light of what i've been discovering, i want to check if the ecu was also upgraded to a manual one. Thing is i'm not sure where to find it or how to get to it. I think I remember that the one in my old supra was behind the glove box on the passangers side? is that right? can any one give me a quick low down on the quickest and easiest way to get to it?
Sweet thanx guys.
Kyosho
Wollongong
Re: ECU and Cruise Control Q RE JZA70 Sat, 06 August 2005 08:46 Go to previous messageGo to next message
There is, on the main toymods page, a downloads section
There's one for the MA70 in there, it has the location within the wiring diagram of both of the Cruise Control, and the ECU...
Have you tried to use the Cruise Control? If so, how did you attempt to turn it on?
ReQuieM
Re: ECU and Cruise Control Q RE JZA70 Sat, 06 August 2005 08:58 Go to previous messageGo to next message
Cool i'll go grab that (i havent been to the main page in a while!)
I did play with the buttons when i had it but it didn't seam to work, i might plug it in and make sure it doesn't. Also i thought that the factory unit wouldn't run with a manual box?
Kyosho
Wollongong
Re: ECU and Cruise Control Q RE JZA70 Sat, 06 August 2005 09:02 Go to previous messageGo to next message
The manual unit will run with Cruise Control, but for safety reasons, you should have an extra switch in series with the brake activated switch but have it on the clutch, so that, when you shift gears, it shuts the cruise control off...
There's a main switch that is NOT located on the steering wheel, I can't remember where it is, but it's on the dash somewhere... From memory it's on the right hand side of the steering wheel near another switch.
It is the main switch to turn the cruise control on with
You CAN run the cruise control without the clutch switch I described above, BUT, you will have to make sure to disengage the cruise control before changing gears.
ReQuieM
Re: ECU and Cruise Control Q RE JZA70 Sat, 06 August 2005 10:25 Go to previous messageGo to next message
Hmmm... the only switches i have on the right hand side are the sunroof and the driving lights. on the left there is a 'spare' space with a flip down coin holder in it but no Cruise switch in sight....
Any idea what it looks like anyone??
Kyosho
Wollongong
Re: ECU and Cruise Control Q RE JZA70 Tue, 09 August 2005 08:34 Go to previous messageGo to next message
ReQuieM wrote on Sat, 06 August 2005 20:25
There's a switch somewhere for it... I know that... LOL
All the *A70 Supras came standard with Cruise Control...
ReQuieM
Re: ECU and Cruise Control Q RE JZA70 Wed, 10 August 2005 03:28 Go to previous message
Dam, thats nice to know. I've given my car a look over and also checked the Mk3 manual off the main page and i couldn't see any switch besides the steering wheel ones. I might plug them back in on the weekend (when i get the dash back together) and see what happens.
Also i have some 'not plugged in' wires leading past the gearbox toward the centre consol could these be it? according to the Mk3 manual i DL'd the should be the seat warmers if i had them.
OH and another stupid Q how/where do i get replacement bulbs for the heat/AC control box? they've got a funky rubber holder and a 14v buld, but the 14v bulb has the back bit 'broken' off and the wire threads through the rubber creating the contact. SO do i brake the back bit off or do i need to source an equiv. bulb?
EDIT: due to bad typin.
[Updated on: Wed, 10 August 2005 03:31]
Previous Topic:putting new cams in a 2tg
Next Topic:Loom Help
Current Time: Sat Oct 17 10:01:59 UTC 2026
Total time taken to generate the page: 0.0043530464172363 seconds
