Toymods » Tech & Conversions » difference between bigport tps?
rthy
Melbourne - NthSubs
difference between bigport tps? Sun, 07 August 2005 08:05 Go to next message
i got a blue top and red top tps sensor, i want to use the blue top tps on the red top, can i do that or are they different?
ChuckLandwehr
Re: difference between bigport tps? Sun, 07 August 2005 13:29 Go to previous messageGo to next message
Check the part numbers on the TPS's, I think you will find they are the same.
cheers Chuck.
rthy
Melbourne - NthSubs
Re: difference between bigport tps? Sun, 07 August 2005 13:36 Go to previous messageGo to next message
cool
ill go check them tomorrow (1 in the car)
c2888
Re: difference between bigport tps? Sun, 07 August 2005 14:56 Go to previous messageGo to next message
The smallport 16v has a different tps, when my brothers bigport went, we replaced it with a smallport, running all the bigport sensors.
The flat in the throttle shaft is 90 degrees out, so it doesn't bolt on. I'd still give it a try cos toyota do some wacky crossovers for the parts.
If you have to have the smallport tps you might be able to swap the whole TB. We didn't try as we didn't have a deep socket at the time.
goodluck with it
dan
Big T
Re: difference between bigport tps? Sun, 07 August 2005 23:04 Go to previous messageGo to next message
c2888 wrote on Mon, 08 August 2005 00:56
goodluck with it
dan
This is correct. I went through the hassle just a week ago when i found out i had a smallport throttle body bolted onto my bigport. I'm in the middle of sourcing out a smallport one.
Eddie.
rthy
Melbourne - NthSubs
Re: difference between bigport tps? Mon, 08 August 2005 10:05 Go to previous message
here is the the pics of the tps, im pretty sure i got that tps off a bigport 4age Confused i still have the t/b, could that be used with the intake manifold? and can the tps be used with the bigport loom/ecu?
http://www.geocities.com/rthy86/Pics/tps.JPG
edit:
part no:
89452 20050
89452 20050
89452 12050
[Updated on: Mon, 08 August 2005 10:11]
Previous Topic:Fuse box replacement, RA40
Next Topic:a 3sge turbo conversion - in the flesh
Current Time: Sun Oct 25 13:50:34 UTC 2026
Total time taken to generate the page: 0.0075089931488037 seconds
