Toymods » Tech & Conversions » 3VZ fast idle
Rob.C
July 2005
icon2.gif  3VZ fast idle Sun, 07 August 2005 08:31 Go to next message
Why is my 3VZ idling fast on start up ? Do they have some sort of cold start injector working during warm up ? Once the temp gauge moves, the idle cuts down to normal.
Re: 3VZ fast idle Sun, 07 August 2005 09:13 Go to previous messageGo to next message
errr... how fast is 'fast'??
Rob.C
July 2005
Re: 3VZ fast idle Sun, 07 August 2005 09:38 Go to previous messageGo to next message
that would help wouldn't it Razz
when starting from dead cold, it will idle at around 1500-2000, once warmed up it drops to 750.
Rob.C
July 2005
Re: 3VZ fast idle Sun, 07 August 2005 09:42 Go to previous messageGo to next message
terra
July 2005
Re: 3VZ fast idle Sun, 07 August 2005 09:48 Go to previous messageGo to next message
normal Smile
but make sure your warm idle is around 800rpm, if its not, you might have a problem with ya engine coolant temp sensor.
the cold start injector is on the left side of the intake plenum, theres a banjo bolt with a fuel line running to the front injector rail, and a solenoid running off down near the belt cover.
[Updated on: Sun, 07 August 2005 09:52]
Rob.C
July 2005
Re: 3VZ fast idle Sun, 07 August 2005 09:54 Go to previous message
Thankx for that. I thought it may have been something wrong with it.
Previous Topic:running turbo on STD ECU
Next Topic:main and big end bearings --> choices??
Current Time: Tue Oct 20 15:53:40 UTC 2026
Total time taken to generate the page: 0.004202127456665 seconds
