Toymods » Tech & Conversions » running turbo on STD ECU
corbet01
April 2005
running turbo on STD ECU Sun, 07 August 2005 08:38 Go to next message
Can i run a turbo using my 100kw ecu? What are those fuel mixture kits you get from jaycar called? Will a piggy back ecu allow thw Std ecu to work with a turbo?
i would to change my small port pistons to GZE pistons.
Sorry for the questions
4agte
Toronto, Downtown
Re: running turbo on STD ECU Sun, 07 August 2005 08:40 Go to previous messageGo to next message
if you skimp on your ecu it may well cost you alot of $$$ in the long run when you melt a piston or 2
berad
Re: running turbo on STD ECU Sun, 07 August 2005 09:22 Go to previous messageGo to next message
provided you run low boost most standard ecu's can run 7psi or so , i know vp comodored do and 92 model rodeos lol.. have been running for about 6 months both of them with no issues
and providing you have a good cooling system and dont flog the shit out of it 24/7 yours should do the same
[Updated on: Sun, 07 August 2005 09:23]
FLAWLES
new zealand up hill
August 2005
Re: running turbo on STD ECU Sun, 07 August 2005 10:07 Go to previous messageGo to next message
yes u can run low boost on the factory ecu
it wouldnt hurt to get the likes of a trd metal head gasket too
i also know a few pple running a fifth injector but this isnt mandatory
if ur worryed about a ecu and or piggy back ecu see the link in my sig
feral4mr2
Bundaberg, Qld.
Re: running turbo on STD ECU Sun, 07 August 2005 10:23 Go to previous message
FLAWLES wrote on Sun, 07 August 2005 20:07
a genuine composite HG or nearly any composite HG will handle a good amount of boost.
depends if you wanna spend the extra $$ getting the block and head prepped correctly to use a metal HG i sopse.
Previous Topic:Please help me with my 1jz swap mkii supra
Next Topic:3VZ fast idle
Current Time: Thu Oct 22 07:54:10 UTC 2026
Total time taken to generate the page: 0.0048320293426514 seconds
