Toymods » Tech & Conversions » wiring 3d to 4agze
rodney
south africa
August 2005
wiring 3d to 4agze Mon, 08 August 2005 06:41 Go to next message
Hi, i am having a problem locating a wiring diagram for a wolf 3d v4 to a 4agze with the dual coil packs, does it still use the std gze igniter? or do i have to install seperate igniters, any help would be appreciated, thanks
4agte
Toronto, Downtown
Re: wiring 3d to 4agze Mon, 08 August 2005 07:28 Go to previous messageGo to next message
wolfs are a bit of a nightmare to wire to gze's good luck with the install
sideshow
Re: wiring 3d to 4agze Mon, 08 August 2005 08:04 Go to previous messageGo to next message
wolfs are a pain to wire up period
u just cant go past a microtech where u turn key and it will start first turn
sebta22
Re: wiring 3d to 4agze Mon, 08 August 2005 09:01 Go to previous messageGo to next message
I have finished wiring up wolf 3d v4 to 4agte with out any major issues. I didnt have 4agze std ignitor so I emailed wolf themselves and they told me to use std bosche ignitor which is simple. I think if you download latest installation manual it calls up a bosche 021/024 coil ignitor. You need two ignitors (unless you buy expensive single dual coil ignitor)and wire it up as per 4 cylinder wastespark arrangement section 4.3.4.2.
When you try (and i mean try) and start the engine you will come across a problem with the CAS trigger. The signal from toyota standard CAS is too weak and causes the sparks and fuel injectors to fire all over the place. You need to order a little black box (approx $70)from wolf (item no. 310-070-400)which plugs directly between ECU and CAS, and eliminates any problems.
Henn
Rosanna, Melb
Re: wiring 3d to 4agze Mon, 08 August 2005 13:23 Go to previous messageGo to next message
With absolutely zero previous wiring experience I wired a 3D V4 to a 4AGZE with no major dramas. Just read the manuals carefully a couple of times. There are good lists of what all the wires in the loom are and basically where they need to go.
I have had no problems running the CAS signal direct to the ECU either. However I do use the variable signal level over the rev range function.
Use a pair of ignitors. Bosch 008 ones from Camiras will do, along with probably many others.
Hen
PS, re-reading it sounds like you may not have the manuals. Get in touch with Wolf and see what they can do about that.
rx793
Perth, Western Australia
Re: wiring 3d to 4agze Thu, 11 August 2005 14:49 Go to previous messageGo to next message
Hey, jsut read that about the toyota standard CAS being too weak. im in the middle of wiring up a 1ggze to a wolf and i was told the standard CAS on that was fine? Would anyone think i have the same problem?
4agte
Toronto, Downtown
Re: wiring 3d to 4agze Thu, 11 August 2005 22:10 Go to previous messageGo to next message
i didnt have any problems with the crank angle sensor as im running a dizzy but the wolf had problems dividing the 24 tooth dizzy into 4 so we had to grind 20 teeth off the dizzy for it to work properly
Henn
Rosanna, Melb
Re: wiring 3d to 4agze Fri, 12 August 2005 00:44 Go to previous messageGo to next message
^^^ I have had no such problems and my CAS still has 24 teeth. It's all in the setup, using SYNC and REF, you have to set how many pulses to skip. It's all in the manuals though, so go have a read.
Hen
4agte
Toronto, Downtown
Re: wiring 3d to 4agze Fri, 12 August 2005 00:54 Go to previous messageGo to next message
yeah it was set to skip the pulses but sill didnt and would only fire on the 4th cylinder however i dont have any faith in my tuner so no doubt part of the problem was him... Altho from what i hear from a few ppl including my tuner was that the manuals are less than helpfull at some times...
sebta22
Re: wiring 3d to 4agze Fri, 12 August 2005 07:48 Go to previous messageGo to next message
I found my number one spark firing all over the place. I looked on tech info number 9 under website and they talk about problems with toyota cas with respect to the ground being for both triggers.
Even with sensitivity set to very low and all the right parameters it wouldnt fire. Put the black box in, bam! first time firing with hiccup without need to modify the CAS
rodney
south africa
August 2005
Re: wiring 3d to 4agze Sat, 13 August 2005 06:24 Go to previous message
Hi, e-mail me ffor the 4agze map for sequential injectors and wasted spark with bosch igniters if anyone wants it, where can i get that cas amplifier?
Previous Topic:3k extractors
Next Topic:home made head studs?
Current Time: Sun Nov 22 22:22:05 UTC 2026
Total time taken to generate the page: 0.015194892883301 seconds
