Toymods » Tech & Conversions » Left of Field–Turbulence and throttle bodies
Gased
icon5.gif  Left of Field–Turbulence and throttle bodies Mon, 08 August 2005 13:49 Go to next message
Fellow techo's
Has anyone given thought to the turbulence that the butterfly valve introduces to airflow and what possible altenatives could be designed?
Take a bottle of water, turn it upside down–see how fast it empties-glug, glug. Same bottle of water, instill in it a rotation by circular motion, turn it upside down and vortex will assist emptying.
Case study: 750 ml Wolf Blass Eaglehawk wine bottle.
Straight (glug) empty: 9.29 seconds
Vortex empty: 4.76 seconds
n=1
Liquid=water (just drank the wine Wink
Any thoughts?
David
Re: Left of Field–Turbulence and throttle bodies Mon, 08 August 2005 14:21 Go to previous messageGo to next message
Do a little bit of searching on the net, and see what you can find about flat slide carbs/throttles, barrel throttles, devices such as Hiclone, and the only one I believe to be truly full of merit, not having throttles, and draw your own conclusions.
Gased
Re: Left of Field–Turbulence and throttle bodies Mon, 08 August 2005 15:27 Go to previous messageGo to next message
hummm,
well I've now looked, any URLs you like best? I feel sad for NA folks, tuning carbs. I use gas there4 vaporiazation is not primarily the issue. Some turbulence is needed for volatile liquid vaporization, poor folks.
The Hiclone device installed after a butterfly valve/throttle was closer to what I had in mind and seems feasible provided enough length is allowed to regularise the flow and some resistance is allowed. But what I'm suggesting is an alternative to restricting flow that leaves at least a lesser non-turbulent air flow after the 'valve'/throttle. Sure bugger up the air flow via a throttle and then try to 'regularize' it via Hiclone type device. I can't draw my own conclusion as I haven't tested Hiclone, I wonder if anyone at Toymods would have chanced their $$s and are humble enough to admit and share their results??? Come on!
It would seem to me a 'generic' vortex unit would be hit and miss.
I would imagine swirl combustion chamber designs were designed for a reason and these could be enhanced by the gas stream entering the chamber in a regular, predictable manner. Better efficiency in inlet flow could imaginably be achieved if more attention was given to either eliminating or reducing turbulence due to butterfly/slide valves by using a more advanced technology vs 'conditioning' the airflow afterwards (which could be a good thing!). I have in mind something but am working on it Wink A lot of effort has been put into liguid fuel injection (when it would be a lot easier just to burn gas-perhaps liguid gas injection excluded)
David
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 00:15 Go to previous messageGo to next message
Swirl ports have been around for a long time, and they work great on low-rpm high-torque engines but become a major restriction if you try to rev the engine hard. For high rev, high performance applications you need a straight clear path from the inlet system to the combustion chamber. Remember you only have a small fraction of a second to get X cc's of air past the valve and into the cylinder, and at high rpm this window becomes very narrow indeed!
nick.parker
January 2005
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 02:34 Go to previous messageGo to next message
In addition to what you are saying. It doesn't matter how you throttle the airflow, as throttling (as name suggests) incurrs pumping losses! Either go diesel Wink or get a valvetronic system from a BMW!!! If you're worried about your butterfly causing turbulence, maybe you could get a slightly bigger one.
In my experimenter mode I might consider an aerofoil shaped throttle blade....though this could present some assembly hassles :-/....depending on the approach..
Cheers, Nick
[Updated on: Tue, 09 August 2005 03:01]
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 03:06 Go to previous messageGo to next message
It's not that hard to eliminate turbulence around the throttle plate, just use slide or barrel throttles as used on some motorbike and race engines. Not as simple or reliable as a conventional butterfly arrangement, but it completely eliminates any flow restriction at WOT.
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 03:18 Go to previous messageGo to next message
Simple solution
Step 1: Remove throttles
Step 2: Remove cams
Step 3: Install variable solenoids to control valves
Step 4: Program ECU
Step 5: Enjoy the fruits of your labour.
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 03:47 Go to previous messageGo to next message
CrUZsida wrote on Tue, 09 August 2005 13:18
Step 2: Remove cams
Step 4: Program ECU
Step 5: ???
Step 6: Profit.
Fixed.
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 03:51 Go to previous messageGo to next message
I was going to do that, but its getting old, so I moved on.
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 04:15 Go to previous messageGo to next message
Gased wrote on Mon, 08 August 2005 23:49
Fellow techo's
n=1
Any thoughts?
David
i think it will empty faster if you break the bottom off the bottle Wink then no glug Razz
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 04:21 Go to previous messageGo to next message
CrUZsida wrote on Tue, 09 August 2005 13:51
BAM!!
ChuckLandwehr
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 05:34 Go to previous messageGo to next message
David, if you are using LPG, get a "Gas Research" Carb they operate on the slide principle, rather than the buterfly.
cheers Chuck.
Gased
icon7.gif  Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 10:44 Go to previous messageGo to next message
Thanks n all,
I'm off trying to find a diagram of a slider carb, never seen one.
Regarding swirl chambers–what I was getting at is if the air within the intake above the valve swirled it would get past valve and into head quicker. The Hiclone is _towards_ what I was thinking of–vanes to get turbulent air regular again. An airfoil butterfly would be better but only at full throttle. Best not to have a throttle valve at all (as I'm being told slider carbs don't) If air travelled centrifugally in inlet ports it would travel faster. While the Hiclone looks interesting I would want to see some real proof of operation.
On a tangent–smooth isn't always best. I've been told a fine mohair jumper, believe it or not, offers less wind resistance than lycra when riding a push bike–it just get bloody hot fast wearing one. Have been told its about 'boundary layers' and laminar flow.
Knitted intake liners...mum? Laughing
David
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 13:28 Go to previous messageGo to next message
Yes, but you have to remember that certain principles apply to certain applications - to quote a friend of mine years ago: (we were starting at an XA Falcon wagon) 'I'm gonna get one of these, cover it in fibreglass and put dimples on it like a golf ball. Then I can go really fast and have no wind resistance.' Come to your own conclusions.
Gas Research carbs are NOT slide throttles, or anything even remotely that classy. Still, if you're a fellow gas nut, why not PM me and we can spend hours talking about silly ideas that other people laugh at...
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 13:48 Go to previous messageGo to next message
Gased wrote on Tue, 09 August 2005 20:44
you mean rough sandcast finish on intake ports perhaps?
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 14:34 Go to previous messageGo to next message
The knitted ones seem so much more homely...
Plus they provide a handy way to catch all that nasty oily scum!
clubagreenie
1st street on the right
Re: Left of Field–Turbulence and throttle bodies Tue, 09 August 2005 21:50 Go to previous message
What if there was a flap like an AFM instead of a pivoting butterfly that remained in the airpath?
Then as River suggested shape it to create favorable pressure systems in the flow.
Previous Topic:Ae94 Corolla What Can i Do?
Next Topic:1JZ-GTE R154 Diff Ratio
Current Time: Wed Oct 21 10:00:22 UTC 2026
Total time taken to generate the page: 0.015430927276611 seconds
